Unread 12-09-2014, 04:19 PM   #1
Jim Cordes
Customs mastic
whats the chance that you guys can make the mastic a little more pliable..maybe its just me but the stuff is pretty stiff. hard to spread...doesn't hurt to ask right?
Jim
Jim Cordes is offline   Reply With Quote
Unread 12-09-2014, 06:25 PM   #2
Steve Taylor
This is always a balance between making it easy to spread and stiff enough to hold tiles on the wall without slipping. The cold will affect the consistency, so I assume you are using it within the recommended temperature range.
I will add this comment to our R&D wish list for them to investigate.
Steve
Retired Tile Industry Chemist
Steve Taylor is offline   Reply With Quote
Unread 12-09-2014, 07:05 PM   #3
Who uses mastic these days anyways with all the good mortars out there with better performance?
Unread 12-09-2014, 07:40 PM   #4
In south Texas Omnigrip has great working consistency, smooth and creamy.
Omnigrip works really well when dealing with a tricky patterned backsplash where 2 square feet is an accomplishment for the day. We've all been there.
Unread 12-09-2014, 07:54 PM   #5
About the only thing I use mastic for is kitchen back splashes. It does give me more time to get it covered and it will stick plenty well.
Unread 12-09-2014, 08:07 PM   #6
Jim Cordes
Good point Steve it is a little cold up here in PA, that prolly had something to do with it..I was using 1/4 square notch and there were spot that didn't want to go through the notches..kinda slid on the wall.
not sure how loose you can make it before it looses it anti sag performance...
or how much the cold has affected it for that matter..actually that might had alot to do with it..
thanks for the response.
oh yea, and yes this was a kitchen backspash, thats pretty much the only place I use mastic also, if it don't get wet and don't get stepped on and the tile is small enough i don't have a problem with mastic...it has it's place
Jim
Unread 12-09-2014, 10:57 PM   #7
PetrH
see if there is a manufacture date on your bucket. Sometimes a bucket that's sat around a warehouse for a couple of years gets like what you described.
Petr
Unread 12-10-2014, 09:59 AM   #8
Swedes Tile
Swedes Tile's Avatar
Anybody remember a mastic called 767 forgot the manufacture but that stuff was some tough mastic.
Swedes Tile is offline   Reply With Quote
Unread 12-10-2014, 02:58 PM   #9
LAN1870
BATHROOM REMODELING
LAN1870's Avatar
I've been using Acrylpro for years (backsplashes). I do remember that it used to be much easier to spread. Now it seems a lot stiffer. I suppose it's a feature to hold tile in place better. I do find that it helps if I mix it with an actual mixer and it's not cold.
Leslie N.
Owner
Bathroom Solutions & Leslie’s Plumbing
"Attention To Detail Comes First"
LAN1870 is offline   Reply With Quote
Unread 12-10-2014, 04:04 PM   #10
Lazarus
Lazarus's Avatar
I can only echo what Paul said. It's good stuff for a backsplash and installations where water is not an issue.
Laz...
Unread 12-10-2014, 04:47 PM   #11
Kilauea
LT
Kilauea's Avatar
Type 1 and type 2. Type 2 may work better for u.
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 12-10-2014, 08:02 PM   #12
don s
ever use Omni grip with glass or porcelain tile on backsplashes ?
Don
Don @ Diablo Tile and Stone
Northern California
don s is offline   Reply With Quote
Unread 12-12-2014, 10:22 PM   #13
Don, Omni grip is good mastic but I usually try to find out what the glass manufacturer recommends. Usually its a highly modified thinset with glass tiles.
Unread 12-12-2014, 10:27 PM   #14
Don't know that we've ever heard of a glass manufacturer that recommended the use of organic adhesives to install his product.
Unread 12-13-2014, 10:08 AM   #15
tileguynky
Which Custom mastic are you referring too?
Please don't change T1-60. It's perfect the way it is. It's smooth enough to spread easily and dries fast enough to set up quickly. The cold is the enemy for me right now. I have a bucket of mastic and liquid w/p sitting in the mud room.
Works great on the glass tile that has the color strip on the back of the tile. Bonds well and seems to be doing well so far. Yes, I know of no glass manufacturer that recommends mastic for bonding glass. I do not think that I would use it to bond directly to glass. Like I said, it bonds well to the paint/paper on the back of the glass.
As a student of FrankenGueuze theories of Tileology, instructions are usually guidelines. Your real world mileage will vary.
Customs uncoupling mortor irish tileguy in michigan Professionals' Hangout 21 09-02-2011 05:11 PM
Multiset customs Full tile Tile Forum/Advice Board 3 08-31-2008 04:36 PM
customs slc opiethetileman Professionals' Hangout 10 12-21-2005 08:07 PM
Customs can't decide! John K Professionals' Hangout 1 05-25-2005 07:56 AM
Customs New Products justin savage Professionals' Hangout 8 03-27-2005 06:27 PM
