Unread 02-17-2009, 12:26 PM   #1
Tile TacticsII
large self level pours need input!
I have a self level pour coming up over infloor heat approx. 857sqft. I know someone out there has done pours as large and larger. Just lookin for advice, you know do's and dont's, or tips that might make the job easier.
Tile TacticsII is offline   Reply With Quote
Unread 02-17-2009, 12:33 PM   #2
crow wing
No shortcuts
I had one last year 1000 sq, used a company out of MLPS mn they were done in about 4-5 hrs great work! could never have done this well with just myself.
Pumper truck, 3guys, Accufloor is the name.
Loghead Mark
http://www.crowwingtile.com
crow wing is offline   Reply With Quote
Unread 02-18-2009, 05:32 PM   #3
Tile TacticsII
Alternative
need to know if there is an alternative to metal/plastic lath used with slc, maybe something along the same lines cost wise, but easier to work with. Lath is to be installed under infloor cable heat system with 3 seperate heating zones. Its going to take about 860sqft. of roll lath to cover area and about 5 billion staples theres got to be a better way???
Michael
Unread 02-18-2009, 05:49 PM   #4
crow wing
No shortcuts
Roll on antifracture membraine will stick it to the floor.
Loghead Mark
Unread 02-18-2009, 08:25 PM   #5
Tile TacticsII
antifracture good idea
But to my understanding the lath gives strength to the slc? besides i dont think i need to worry about adhension to the subfloor since its all going to be primed with latex.
Michael
Unread 02-18-2009, 09:53 PM   #6
MNTileGuy
Central Texas Tile Guy
I used to live up in you guys' part of the world. I was semi-familiar with accufloor. They definitely had the setup for major pours, but I doubt they'd travel beyond a couple of hours of the Twin Cities.
It can be done to pour that much by hand with several guys going it at. If you have enough guys mixing, carrying and dumping that you could just be in charge of screeding, it's doable.
I don't think there's a way around the lath, sorry to say. That's what helps give the SLC strength over a wood subfloor. Don't forget primer too!
I'd also make sure that the heat cables are well secured-don't assume the electricians have done this! The cables have a nasty tendency to float to the top. In fact, some folks do 2 seperate layers of SLC since in one pour the cables can float to the top, even in a deep pour. I speak from experience on that one.
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Putting large tile on Kerdi shower wall ruthie_remodels Tile Forum/Advice Board 8 09-11-2006 05:42 PM
Floor level like Sand dunes - please help scorleo Tile Forum/Advice Board 7 05-30-2006 08:22 PM
Pan Liner done and Drain not level Tampal Tile Forum/Advice Board 1 05-16-2006 05:42 AM
estimating a large remodel opiethetileman Professionals' Hangout 8 02-25-2005 06:40 AM
getting subfloor installed level jwray Tile Forum/Advice Board 6 11-10-2003 10:44 PM
