Unread 05-25-2008, 02:50 PM   #1
Valeri
Thumbs down backsplash against wood cabinet
Do I have to put hardiboard on the backsplash if it is going against wood cabinet, can I just tile on the side of cabinet? I have hardiboard over the sheetrock part of backsplash.......My first countertop.....Valeri
Valeri is offline   Reply With Quote
Unread 05-25-2008, 05:32 PM   #2
muskymike
muskymike's Avatar
Hi Valeri, you could have just stuck the tile to the drywall no Hardi needed. I suppose if it's a small area on the cabinet you could stick the tiles with some liquid nails
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 05-25-2008, 06:13 PM   #3
Ken
welchtile.com
You might consider a Polyurethane glue to stick to your cabinets, just a second option... not the best, but should work
I would recommend this product:
PL® Premium is a polyurethane adhesive that provides superior results and is safer to use. PL® Premium generates three times the power of traditional construction adhesives. It may be used inside or outside and will last as long as the surfaces it joins together.
I used it to bond together 700+ brick edgers to edge my planter boxes and driveway outside. That was over 6 years ago, and they haven't move a bit or broke bond.
Ken
Ken is offline   Reply With Quote
