Unread 11-29-2005, 11:52 AM   #1
bhammerstrom
KERDI-Drain at sloped fill
I'm doing a slate bathroom floor with a drain in the middle and want to keep the system as thin as possible. 3/8" slate o/ Ditra (Kerdi-Banded seams) o/ double 3/4" pwd o/ notched existing joists on a new girder (L/1813).
How thin can I start the sloped fill around the drain. The literature says "the drain casing and bonding flange must be fully supported" and the section shows mortar under these but no mention of thickness that I can see. It looks like about 1/2". I don't imagine it can sit right on the underlayment??
Brad
bhammerstrom is offline   Reply With Quote
Unread 11-29-2005, 11:57 AM   #2
MarcusEngley
MarcusEngley's Avatar
Got to have something under there -- 1/2" is pretty thin, I think. Most of pros here seem to like to see 3/4" minimum. Hang tight for them to chime in...
Think your floor meets deflection specs? L1813! Yikes! You parking cars in this bathroom?
Marcus
(not a pro -- that's the disclaimer)
My Bath Project
MarcusEngley is offline   Reply With Quote
Unread 11-29-2005, 12:49 PM   #3
bhammerstrom
Marcus,
Deflection without a girder is L/430, not up to L/720 needed for slate. I could sister to the existing and get L/916. Client is a large man bouncing along in a mortized wheelchair, so prudence is called for, I believe, no?
Brad.
Unread 11-29-2005, 01:11 PM   #4
MarcusEngley
Definitely -- I was making a joke. If I could get my whole house to L1813, I would, just for fun!
Marcus
My Bath Project
Unread 11-29-2005, 01:22 PM   #5
Mike2
Head on over to our Liberry Brad, look for the Kerdi Drain - Rough In article. It should give you all the info you need incl. thickness of mortar bed at drain location.
