Unread 06-09-2021, 07:43 PM   #1
bocman93
Waterproofing grout
Hi!
I did my first shower and make a mistake. Drain little over tile and water stays around it
Do you now some sealers that can really waterproof grout?
I use Miracle sealer but don't really think it work
Vova
bocman93 is offline   Reply With Quote
Unread 06-11-2021, 06:59 AM   #2
Hi Vova, welcome. Usually the easiest way to fix the problem is to lower the drain. The tiles around the drain would need to be removed and the drain screwed down so it's even with the tiles. If it's not possible for the drain to be lowered, then the floor would need to come up higher.
Sealer isn't designed to waterproof the grout. About all it will do is make the grout easier to clean. And, the grout isn't part of the shower's waterproofing. The waterproofing is under the tiles.
We could help more if we knew more about how the shower was installed, especially the shower floor.
Unread 06-25-2021, 05:43 AM   #3
bocman93
Thank you, that what I thought too.
I'll try to cut tile with multi tool and after I need to sand the mud below drain so I can lower it
Vova
Is completely waterproofing grout possible? fertilemyrtle3 Tile Forum/Advice Board 8 05-30-2008 08:30 PM
Is there a waterproofing sealant for grout? JoeyC Cleaning, Restoration and Sealing 3 06-26-2007 10:13 PM
Waterproofing Grout DavidC Tile Forum/Advice Board 3 12-19-2006 12:31 PM
question for waterproofing shower grout moetker Cleaning, Restoration and Sealing 2 06-04-2006 12:10 PM
Waterproofing grout Edward Tile Forum/Advice Board 12 12-08-2004 08:53 PM
