Unread 09-02-2017, 08:52 AM   #1
fhueston
cement back board over concrete slab
Just looked a stone installation failure where they used a cement backer board over a concrete slab. I cant find any guidelines for this. Would you ever use CBB over a concrete slab. If so why? Going to use this failure in my next stone inspection class...classic failure.
Fred
fhueston is offline   Reply With Quote
Unread 09-02-2017, 11:58 AM   #2
eurob
Not...Sure
Was the CBB full coverage bonded ?
What was the stone failure ?
Roberto
Unread 09-02-2017, 03:19 PM   #3
fhueston
failure was lack of bond...there was still trowel marks in the thinset.
Fred
Unread 09-03-2017, 01:38 PM   #4
tilemanct
Tile & Stone
Fred
How many years did you install before starting to teach? Knees or back give out?
CTEF Certified Installer
Unread 09-03-2017, 03:09 PM   #5
fhueston
Im 64 and started with my dad when I was 10.,,,so you do the math. LOL
Fred
Unread 09-03-2017, 04:54 PM   #6
CBU is required to mechanically fastened to the substrate. That would be quite the challenge over SOG
Unread 09-03-2017, 05:14 PM   #7
eurob
Not...Sure
I think the requirement for mechanical attachment to the substrate -- plywood -- is for the deflection , where the concrete slab does not deflect. I don't see any potential problem with the CBB properly adhered with mortar , except for compression . And that may only be problematic if left uncovered .
Why would someone go to the trouble of using CBB over the SOG , where mud or SLC could be used ?
Roberto
Unread 09-03-2017, 08:12 PM   #8
And I believe it has nothing at all to do with the deflection of the substrate, which is quantified as a requirement by the CBU manufacturer. It has to do with fastening the panel to the substrate.
While it might be possible to set the CBU on a concrete substrate, it would be much like setting thin tile panels and that's not an easy thing to do. It also makes no sense to me at all to even attempt. What might be the purpose?
Unread 09-04-2017, 07:56 AM   #9
I would mud it up, myself but Wedi claims their board can be used.
https://www.wedi.de/en-us/areas-of-a...rete-subfloor/
Unread 09-05-2017, 02:59 PM   #10
Steve Taylor
Cement backer unit must be mechanically fastened to the substrate. The structure of the CBU is not designed to be adhered to a substrate like a tile. The product is not structurally sound like plywood. We have had people try this and they nearly always fail. I agree they should have done a bonded mortar bed.
Steve
Retired Tile Industry Chemist
Steve Taylor is offline   Reply With Quote
Unread 09-05-2017, 07:58 PM   #11
PetrH
makes completely good sense to me, " need to raise the floor 1/2", but the minimum mortar bed thickness is 3/4, let's just glue down some Hardi" Too bad it doesn't work out in the real world. Though, I can't really think of a good reason why it would not work. I mean like Steve said it doesn't work, but I really don't understand why, provided you get a good bond over and under.
Petr
Unread 09-06-2017, 03:44 PM   #12
Petr,
Hardi-backer can actually delaminate. I've seen it more than once. And cement backer can pull apart also. That's what Steve means when he talks about the structure of the board. The stuff really needs mechanical fasteners.
Unread 09-06-2017, 05:13 PM   #13
Steve Taylor
If you need a 1/2" or less adjustment, you may want to consider a self leveling underlayment. We are seeing more and more of this used to get a perfectly flat floor.
Steve
Can I place tile on plywood with no concrete back board? MR25 Tile Forum/Advice Board 7 05-08-2011 09:31 PM
best cement back board? acid Tile Forum/Advice Board 29 02-08-2011 03:34 PM
Use existing slab or replace with cement board Cooper 1 Tile Forum/Advice Board 13 12-02-2007 12:39 PM
Has anyone ever mortared cement board onto concrete? stage rat Tile Forum/Advice Board 24 10-20-2005 07:14 PM
cement board on concrete trout Tile Forum/Advice Board 10 03-30-2005 02:23 PM
