Unread 03-03-2017, 08:35 AM   #1
RM91
Mesh back on Kerdi ceiling
About to set my shower ceiling tile in my new master shower. Ceiling is Kerdi (steam shower). i'm using small 2x4 porcelain mesh back tile for ceiling. Question is:
1. What is the best thinset technique for bonding this tile to my Kerdi ceiling?
2. Should i burn thinset into back of each little tile?
Concerned about getting full coverage.
Ryan
RM91 is offline   Reply With Quote
Unread 03-03-2017, 09:39 AM   #2
RM91
One more question before i begin tiling, is there any danger of starting and stopping my wall install for a day? Does the thinset need to be continuous on the walls for any reason.
Ryan
Unread 03-03-2017, 10:18 AM   #3
rmckee84
rmckee84's Avatar
2'x4'? Solid tile or mosaic?
1. 100% coverage and a non sag mortar is how I like ceilings done. Laticrete tri-lite and ardex x77 would be my top choice. Backbutter the tiles if they are solid tile, if they are mosaics I comb out thinset on a scrap piece of backboard with a small v notch then set the tile on that. Then pull it up and install on the ceiling. Doing this will transfer thinset onto the mosaic similar to backbuttering but with less mess.
2. See above
You can stop and start as you please
Ryan McKee
Unread 03-03-2017, 10:22 AM   #4
RM91
its mosaic (if i understand that correctly), 12"x 12" sheet,
I set the Kerdi with Kerabond T, was planning on using it to set tile too, only concerned on ceiling with bonding
Ryan
Unread 03-03-2017, 10:40 AM   #5
rmckee84
rmckee84's Avatar
It will probably be fine, I just prefer to use a non sag thinset. I havent used kerabond t so I can't speak to how well it will preform on the ceiling.
Ryan McKee
Unread 03-03-2017, 11:07 AM   #6
RM91
i appreciate your help, ill let you know how it goes.
Ryan
installing mesh back pebble tiles on schluter shower pan Bobbie Tile Forum/Advice Board 16 06-23-2013 01:32 AM
plastic film stuck to mesh on back of tile dgibby Tile Forum/Advice Board 11 09-08-2010 10:54 AM
BACKSPLASH-Mesh or no mesh? Which is easier for beginners? kcaven Tile Forum/Advice Board 2 02-07-2007 05:43 PM
what type of adhesive is used on for a slate tiled shower floor?1"sq mesh back bighthis Tile Forum/Advice Board 8 11-13-2006 01:46 PM
Trowel for mesh back mosiac? MChartre Tile Forum/Advice Board 2 07-10-2005 10:57 AM
