Unread 05-28-2013, 01:28 PM   #1
cmarft
Blotchy natural stone tile after install!
About a week ago, I had natural stone installed on my fireplace. I believe the stone is slate. After the installer installed and grouted, the result was ugly and blotchy (see photo). The stones were uniform out of the box. Could this be the wrong choice of adhesive? thanks!
Carl
cmarft is offline   Reply With Quote
Unread 05-28-2013, 02:35 PM   #2
JTile
Southern Delaware Tile Contractor
JTile's Avatar
Kind of tough to give any gueses without some more information. You think its slate... any way to confirm that? What type of adheisive was used? What was the stone set over? What kind of grout was used?
Have you talked to your installer about this?
Justin
Kyle's Tile LLC
Ocean View, Delaware
www.KylesTile.com
JTile is offline   Reply With Quote
Unread 05-28-2013, 07:57 PM   #3
LGB
Tile Contractor -- Pennsylvania
It's moisture from the thinset. Give it some time, it will go away.
Leon
LGB is offline   Reply With Quote
Unread 05-28-2013, 08:06 PM   #4
I agree on the moisture from the thinset. How long between setting and sealing?
Unread 05-28-2013, 08:09 PM   #5
Screw Loose
Thinset on my fingers
Screw Loose's Avatar
Yeah, that stone is just bleeding the water off of the thinset.
Give it about a week, it should clear up beautifully.
Then seal it.
Worst case scenario is that it is grout haze, or the installer didn't pre-seal the tile before grouting.
But here's to hopin' that it's just the moisture!
Christian
Blog of some of my works
Screw Loose is offline   Reply With Quote
Unread 05-28-2013, 08:18 PM   #6
I agree, hopefully it's the moisture from the thinset. But, if mastic was used, it's possible it could do the same thing and would take much longer to dry out. I have seen moisture from thinset take 4 to 5 weeks to dry out. Keep us posted.
Unread 05-28-2013, 08:21 PM   #7
Pointing a box fan towards it will help
Unread 05-29-2013, 08:52 AM   #8
Most people think of stone as being impervious...but, many of them actually do absorb moisture. If you have a scrap of that stone tile, wet it with a sponge, and you'll probably notice the color change that matches that on the wall now. My granite tile took weeks to return to its 'normal' coloration after setting. If you like the color of it when wet, you can seal it (after it dries out first!) with an enhancing sealer, and that will approximate the 'wet look'. I found that I liked the look of mine 'wet', and did put on an enhancing sealer - the colors are more vibrant, but that may not be what you're looking for and a 'normal' sealer won't change the color much, if at all.
Unread 05-29-2013, 12:03 PM   #9
jim_c
doitmyselfer
If your tiles are slate you will find that they really respond to enhancing sealers. Our slate fireplace went from dull to brilliant with the glossy treatment we used. Good luck with the drying, if that really is the issue.
Jim
jim_c is offline   Reply With Quote
Unread 05-29-2013, 12:20 PM   #10
jim_c
doitmyselfer
Slate fireplace
glossy look
Jim
Unread 05-30-2013, 09:03 AM   #11
Looks like the same slate I used on my fireplace, Jim, looks great.
install of natural stone vs ceramic scottparris99 Tile Forum/Advice Board 5 10-17-2012 04:19 PM
HELP!!! Natural Stone TRAVERTINE Grout in natural NOOKS and CRANNIES tonydutt Tile Forum/Advice Board 18 08-28-2007 06:58 AM
Natural Stone Tile Roggie Bourque Tile Forum/Advice Board 2 08-23-2006 03:21 PM
First natural stone Install. Mudbed or alternative? LiveINanIgloo Tile Forum/Advice Board 4 06-30-2005 05:38 AM
Natural Stone Install floor support markd Tile Forum/Advice Board 7 06-10-2003 05:53 AM
