Unread 06-16-2006, 05:50 AM   #1
Maha
Talking Composite Stone
Which is better for a kitchen worktop: Composite Stone or Granite? The composite stone is more expensive than the granite, does that sound right to you?
Maha is offline   Reply With Quote
Unread 06-16-2006, 06:52 AM   #2
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
Natural stone is way better. It is heat resistant, and if you get the right one, absolutely impervious too. It looks way better than the plastic stuff and is the only counter surface that is guaranteed AT LEAST 100% return on value when doing improvements on your property.
Engineered stuff has a big marketing hype, but loads of fine print. They seem to think too that the price will lend something to it's quality. NOT
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Unread 06-16-2006, 07:08 AM   #3
Maha
Thanks for your reply. :O) Composite stone is not plastic though, it is made out of marble, granite, quartz, etc.
Does that change your answer or is granite still better? Thanks so much!
Unread 06-16-2006, 07:13 AM   #4
GraniteGirl
Ms. Makita
Maha - what I said about fine print
Marble, quartz and what? The answer is plastic resin. It is the "glue" that holds the pieces of rock together. By weight it is 97% stone and 3% resin (or whatever ratio they claim) but by volume the ratio is considerably different. The composites will burn and melt, and often do so.
Terazzo has a cementatious matrix, and that would be heat resistant - think concrete counters here.
Natural stone is the way to go
Adriana
Unread 06-16-2006, 10:31 AM   #5
MasterGranite
I'm with GraniteGirl on this one. When we attach sink ancors to granite and use a torch to dry off the stone when we attach the achors and I tried the torch on a sample of the silestone which is a brand of composite granite and the sample caught on fire in about 5 seconds!
Bob Brown
b.bobrown@verizon.net
Volpetile.com
215-957-6497
MasterGranite is offline   Reply With Quote
