Unread 10-10-2011, 01:10 PM   #1
marbleheidi
reusing marble countertop
I'm a small DIYer with big dreams and zero knowledge. It's a good combination! My question is, can marble kitchen countertop be reused? We moved into a home with an old counter in the basement, 8ft x 16in, about 1.25 in thick. Can the marble be sliced in half, made into tiles and be used as a fireplace surround? This probably sounds weird, but I'd love to reuse the material if possible and that's the only thing the house needs. But I won't have enough if I can't slice the thickness in half and use both parts.
Heidi
heidi
marbleheidi is offline   Reply With Quote
Unread 10-10-2011, 05:07 PM   #2
Lazarus
Lazarus's Avatar
Heidi~ If you have a saw capable of it, there is no reason why you can't. Having said that, ALL the edges will be sharp an you should use a "stone" to polish them to an acceptable degree.............
Laz...
A man who carries a cat by the tail learns something he can learn in no other way.
Unread 10-10-2011, 05:35 PM   #3
Marge
Marge's Avatar
Heidi, welcome to the Forum.
I'm not sure I understand what you are attempting to cut. Are you asking if you can slice the 1.25" thickness in half (changing it to 5/8" thickness) and use the top and bottom of the counter? Or cutting up the counter and keeping the 1.25" thickness?
Marge------
Unread 10-11-2011, 04:51 AM   #4
I think that's exactly what she's asking (cutting the thickness in half), and I think the answer is no, not with DIY grade equipment. Even if you could cut the slab into tile-sized pieces, you'd have to slice them (diamond bandsaw) and polish at least one surface, probably both. You could buy new material for much less than the cost of the supplies or labor if you had this done for you.
The only way this makes sense is if a) this was a very rare stone that must match other stone in the house, and b) you were doing an authentic restoration of a historically significant house.
Unread 10-11-2011, 01:49 PM   #5
marbleheidi
Bob, you've got it exactly right. And answered my question, but just to be sure, what I understand is that it's unlikely I could find a professional to take my counter, slice the thickness in half and make tiles (or smaller sizes anyway) for less than it would be to simply buy the material new. I suppose I was thinking I could get this cut as if it was wood and pay by the cut and then polish it myself. This marble isn't rare!
Heidi
heidi
Unread 10-11-2011, 02:32 PM   #6
fishin_pol
granite or marble 12" tiles are from anywhere between 2-5 bucks apiece. Using the old stuff and cutting and polishing would be 10-20x the cost.
Phil
fishin_pol is offline   Reply With Quote
Reusing Tile TGINFLORIDA Tile Forum/Advice Board 4 04-16-2011 08:37 PM
Reusing Underlay gl1818 Tile Forum/Advice Board 2 08-19-2009 06:00 PM
marble countertop?? bullit34 Tile Forum/Advice Board 8 02-20-2007 09:34 PM
Reusing Backerboard? nutmeg44 Tile Forum/Advice Board 6 02-15-2007 09:10 AM
reusing old slate Marty Tile Forum/Advice Board 23 12-14-2004 06:37 PM
