Unread 05-05-2008, 08:28 AM   #1
Jbjafarian
Skim Thinset Over Entire Shower?
After Thinset & Mesh over all of my backerboard joints, I am unhappy with the smoothness, or lack-of, left behind. I have already used a grindstone to smooth some of the area, but I am considering skimming the entire shower area with a thin layer of thinset.
My question is... Will the layer of thinset be just as suitable for bonding with the tile as the backerboard would have been?
Thank you!
-Justin
Jbjafarian is offline   Reply With Quote
Unread 05-05-2008, 08:43 AM   #2
ddmoit
ddmoit's Avatar
Yes, it would, Justin, so long as you kept the thickness under 1/4".
I'm not convinced that this is the easiest/best solution to your problem though. Could you give us more details?
Dan - a DIYer in SE Tennessee
Unread 05-05-2008, 02:53 PM   #3
Dan in Texas
I'm NOT a pro but I have done 2 showers so far. On the last one I skimmed on some thinset becuase I thought the wall was way out of wack. I ended up grinding much of it back off when setting tile. You might wait and see how the tile is going down before you spend the time fixing a problem you may not have. Dan
Dan in Texas is offline   Reply With Quote
Unread 05-05-2008, 03:47 PM   #4
kerdibird
Dan's got it man. Use a bit more thinset when you set them, and go with it.
kerdibird is offline   Reply With Quote
Unread 05-05-2008, 04:02 PM   #5
unless the tile is a 4x4.
which I hope not.
I would use a deeper trowel if the tile are big.
^^Check out our Blog^^
Unread 05-06-2008, 07:45 AM   #6
billybish
I agree with Dan. My backerboard joints were definitely less than ideal due to poor execution on my part (lazyness ) and I found that the thinset was accommodating. I ended up with very flat tile despite the joints not being flat.
Billy
billybish is offline   Reply With Quote
