Unread 02-07-2006, 04:00 PM   #1
customceramicsllc
licensed tile installation
customceramicsllc's Avatar
Wink Wetsetting Techniques
please post your tips and methods here for me to look through. cement mix ratios,wire ,consistency,burning in thinset ,skimming backs of marble etc
thanks a lot
john
John
perfection doesn't start with the tile guy
dead fish go with the flow
customceramicsllc is offline   Reply With Quote
Unread 02-07-2006, 04:35 PM   #2
Rd Tile
Tile Man
Rd Tile's Avatar
What do want to know, how to mix mud, then set the stone the next day or at the same time?
I mix my mud 4 parts damp mason sand to 1 part portland cement, just wet enough so that holds together in a ball without water sqeezing out of it, this is packed 1 1/4" to 2" thick over a layer of 15LB. roofing felt and 2.5 wire lath, next day or two, I set my tile or stone using a good modified thinset, that's how I use it.
I never have tried setting while mudding, others will explain how they do it.
I backbutter all porcelain, any size, and backbutter all tile or stone over 13".
Burning in the thinset is done no matter what over everything, flat side then notched side.
Unread 02-08-2006, 09:01 PM   #3
customceramicsllc
do you set up bars all around and pull a screed ? do you do the whole floor in one shot?how do you fix your wire?
John
