Unread 01-12-2006, 03:39 PM   #1
Floorit
Tile, Stone and Hardwood
Floorit's Avatar
Exterior Balcony Job
I have a exterior balcony to do and would appreciate any input into how you would handle this job.
This is new construction, 3/4" plywood (presloped 1/4" / foot) over the front entryway. The fascia board is set 1 1/2" above the level of the plywood. The job is about 200sf.
I was planning to do a traditional mudbed up to the level of the front fascia board (w/ expansion joints) covering that with Ditra waterproofed w/ Kerdi band and finished with a drip cap at the front and sides.
Ray
Floorit is offline   Reply With Quote
Unread 01-12-2006, 03:54 PM   #2
Scooter
Remodeler -- Southern Cal.
Scooter's Avatar
Location would important information, including temperature and rain levels.
I would do a preslope, would install a membrane, put TROBA on top of the membrane, then the final setting bed, also sloped away from the house.
I'm not a Ditra guy, and don't believe it is waterproof (or at least as waterproof as a sheet membrane), but others will correct me if I am wrong. In any event, I would make that Ditra slope away from the home.
Scooter
WC Fields, "Its a Gift" 1934
Unread 01-13-2006, 11:17 AM   #3
Floorit
Floorit's Avatar
The job is in Tennessee, so there will be some freeze/thaw cycles and a significant amount of rain.
After a 1 1/2" mudbed is put in, I would only have about 3/4" left before running into problems with the doors. Can you lay the bonding coat directly to the Troba? From what I've seen, the Troba has to be covered with an additional layer of mortar and then tiled.
Unread 01-13-2006, 01:50 PM   #4
e3
Troba needs a mortar bed over it..It makes for a great system however if you don't have the space another option would be Nobledeck.
Eric
Noble Company
Unread 01-13-2006, 05:50 PM   #5
Dave Gobis
da Man!
Dave Gobis's Avatar
I have only two words to say, flashing and railings. How about it?
Unread 01-13-2006, 05:54 PM   #6
e3
if thats to me, they both have to be dealt with.
Eric
Noble Company
Unread 01-13-2006, 06:02 PM   #7
Dave Gobis
da Man!
Dave Gobis's Avatar
No, that is to anyone thinking about a deck, you tell them Eric, you get the calls more than I do I'm sure.
Unread 01-13-2006, 06:10 PM   #8
e3
another point is --its a bad idea to penrtrate the membrane every 2', in both directions, to hold form boards for a decrotive concrete pour..
Eric
Noble Company
Unread 01-13-2006, 06:29 PM   #9
Scooter
Scooter's Avatar
Ray, the typical application of TROBA is in this order:
Preslope, membrane, TROBA, mud bed, thinset, tile.
It is a drainage mat, and is designed for outdoor systems where there is a lot of moisture. It drains the mud bed using gravity, and keeps it dry, so in the event of a quick freeze after a long cold rain or melting snow, the moisture in the mud bed doesn't freeze and crack the mud bed.
I can't tell you if you have enough space for what you are doing, but in any event, whatever membrane you use, be it sheet or Ditra or Kerdi, make sure it slopes. Dave, as always, has a good point about flashing and counter-flashing.
I'm not quite understanding the rail point, but yes you need to have them.
Scooter
Unread 01-13-2006, 06:34 PM   #10
opiethetileman
opiethetileman's Avatar
what is flashing?? is that when you stand on the balcony and flash the neighbors your new tile before you install it
opiethetileman is offline   Reply With Quote
Unread 01-13-2006, 06:44 PM   #11
Dave Gobis
da Man!
Dave Gobis's Avatar
Lot of the failure calls are membrane penetrations from deck railings, isn't that so Eric? Speak up now, I know it isn't fishing but you have to work once and awhile to buy bait.
Unread 01-13-2006, 07:01 PM   #12
Floorit
Floorit's Avatar
Thanks for the replies, you share some of the same concerns I have regarding any balcony work.
I have already told the builder that I'll need to bring the membrane a minimum of 3" up the walls to facilitate drainage and to make sure water can't get between the tile and the structure.
I also agree on the railings. If they are attached through the membrane, the whole job is subject to failure. As I understand it, the railings are supposed to be iron. One of my thoughts was to require the railings be in place prior to starting the job, and working around them.
Unread 01-13-2006, 07:14 PM   #13
jd77
Tile and Stone Setter
jd77's Avatar
Hi Ray,
Since you are in the freeze/ thaw climate and the deck will be taking on water - here's what I would do:
  • Since you already have a preslope install a 45mil EPDM membrane over the plywood and flashing up the wall.
  • Then lay down the Troba Plus membrane. The air space in the Troba will become the dew point rather than the joist space inside the house.
  • Float your mud bed using 14ga 2x2 wire reinforcing in the center of the bed.
  • Either set your tile directly to the mud or install Ditra/ Kerdi band first for your primary waterproofing. This will get the tile above the fascia board.
If you don't use the Ditra/ Kerdi band you will have to remove the fascia board to allow the water to escape from the Troba at the bottom of the bed.
If you use railing the penetrations will have to be dealt with as well. Depending on the type of railing you use you could build a pan around each anchor and fill with urethane.
It would also be a good idea to flash up the wall with Kerdi and install some base. This system ( with the Ditra/ Kerdi band ) will keep the water out of the bed and also give you a backup just in case.
Good Luck
JD
"Consider any individual at any period of his life, and you will
always find him preoccupied with fresh plans to increase his comfort."
Alexis de Tocqueville
jd77 is offline   Reply With Quote
Unread 01-13-2006, 08:28 PM   #14
Dave Gobis
da Man!
Dave Gobis's Avatar
If your going to use EDPM in that type of installation it and the seaming would have to be alkaline resistant. That is hit and miss in an unrated product for tile. This has been a discussion item in the past and reflects the opinion of their trade group and technical committees. The issue is long term, it gets "punky" or soft.
Unread 01-13-2006, 09:22 PM   #15
Couple other points on your plan, JD:
How ever would we know that?
If he's gonna have a drain plane below the top of the facia board, be it a primary or secondary drainage, he's gonna hafta make provisions for that drain to see daylight, either by removing the facia or moving it away from the edge of the floor, no?
Ray:
The system that's being described is method D-EXT-OS-04 in the Schluter Installation Handbook if you have access to a copy of that. They've got some special flashing and edge trim pieces, too, if you can figger a way to adapt them to your situation.
And I sure agree with installing the railing newels first and waterproofing them along with your installation.
