Unread 04-13-2011, 10:21 PM   #1
bob Campbell
A retired shop teacher asks:
Can you help please?
My subject areas were auto, welding, woods etc. Tile is new territory. I want to apply porcelain tile directly to sheet vinyl flooring. The vinyl is well adhered to the cement underlayment. I purchased 12 x 12 tiles and layout is a done deal. The mortar I was sold is Versabond, a modified thinset mortar reccomended by the "sales associate" (a young lad not a tradesman) was what I needed. Is this the best choice?
Prep work included scrubbing with ammonia/Lysol mix followed by surface sanding with 100 grit and a final cleaning. Input Welcome.
Bob
bob Campbell is offline   Reply With Quote
Unread 04-13-2011, 10:55 PM   #2
dhagin
Welcome Bob,
Personally, I'd remove the vinyl as the tile installation will only be as good as the vinyl installation otherwise. Versabond is appropriate for going over vinyl sheet flooring as long as Customs prep is followed. Follow all their recommendations for prep and install. You may want to bump it up a notch and get a stickier thinset like Versabond Flex or Flexbond or ... lots of others... If going over vinyl, I'd spend the money on a premium modified mortar.
http://www.custombuildingproducts.co...er=diy&lang=en
dana
Unread 04-13-2011, 11:24 PM   #3
If the vinal is cushioned, I don't think it will end well. Normally, the recommendation is to bite the bullet and scrape it off down to the slab. Then, you might find that there are cracks in it that need to be addressed. And, if you find a crack that has different elevations rather than just a spreading, you probably shouldn't tile it in the first place.
JB member asks for help with Ditra Renron Tile Forum/Advice Board 3 07-16-2008 04:29 PM
My Teacher ARANDAFLOORING Professionals' Hangout 18 11-25-2007 06:24 PM
Newbie asks: tile over cement? pmulry Tile Forum/Advice Board 16 06-23-2003 07:38 AM
