Unread 05-07-2015, 04:15 PM   #1
slayer73
Tile leveling system?
I am looking at getting into a tile leveling system and I am looking for input on what brand works and suggestions. I have been doing quite a bit of planks tile and hate lipage. I was looking at the QEP brand and it looks like you can get them fairly in-expensive. What are everyones thoughts? Thanks!
Ryan
"If you don't open your mouth nobody will know how stupid you are".......I should have listened!
slayer73 is offline   Reply With Quote
Unread 05-07-2015, 04:39 PM   #2
Ryan, please type leveling into the Advanced Search feature and ask for Titles. You'll find a good number of discussions about the various systems. Would help if you limit your search parameter to the Professionals' Hangout, but it's not required.
Unread 05-07-2015, 11:18 PM   #3
Custom Builder
Custom Builder's Avatar
I use 3 different types depending on what is needed. Qep lash where there is plenty of room behind the tile, Tuscan seam clips where there are multiple layers of Kerdi, and Proleveling for the cross sections. For the money, the lash system works great, but the clips are quite thick.
Jason
Custom Builder is offline   Reply With Quote
Unread 05-10-2015, 08:57 PM   #4
tomormatt
I am definitely not a prop, but have done several tile jobs on my house. I made the investment in the mlt system a year ago while doing a floor that was already a bit tricky for me. Although the initial cost is not trivial and the cost to replenish the clips that stay under the tile is also expensive, I am very happy with the product. It is relatively easy to use and has a pretty short learning curve. My thinking is that cost is a bargain relative to having to redo any tile work that has lippage. Absorbing the materials cost of redoing would suck, but factoring the time to pull up and redo made the cost / value of the mlt system an easy choice for me.
That said, I have watched some pros do work in my house and they seem to get a great result without using anything so your incremental benefit may be different depending on your skill.
Matthew
tomormatt is offline   Reply With Quote
Unread 05-10-2015, 09:09 PM   #5
LASH thickness;
Unread 05-10-2015, 11:18 PM   #6
ShortChop
There's currently an MLT system in the For Sale section here that could save you a few bucks over buying brand new.
Jason
ShortChop is offline   Reply With Quote
MLT Systems (Tile Leveling System) ceramictec Professionals' Hangout 1629 12-22-2020 04:49 PM
Economical Tile Leveling System Jaxx Tile Forum/Advice Board 8 11-05-2014 04:22 AM
What tile leveling system to buy for DIY projects? alina_1 Tile Forum/Advice Board 10 06-19-2014 02:14 PM
Self-leveling countertop system for ceramic tile Dale Watnee Professionals' Hangout 34 02-17-2002 10:47 PM
