Old 08-10-2018, 07:16 AM   #1
ahlorenz@icloud.com
Rust and Mildew on stone shower tile
I had a stone shower installed two years ago I notice rust appearing on the grout I would clean and it would go away. I had my tile person come back in a couple of months ago and cleaned the whole floor and resealed now i am getting rust and black spots mostly in back of shower not very happy. I feel I should not be seeing this at all especially after resealed. What should I do?
Anne
ahlorenz@icloud.com is offline   Reply With Quote
Old 08-10-2018, 07:50 AM   #2
Hi Anne, welcome. It's hard to say but I have seen iron deposits in the stone that will rust. I have also seen certain grouts leave black spots.
Do you know what brand of grout was used?
Do you know how the tiles were installed, what's behind the tiles?
What sealer was used?
Old 08-10-2018, 11:24 AM   #3
Dave Gobis
da Man!
Dave Gobis's Avatar
The rust is iron oxide which is a common mineral in stone. Looking at the mold pattern I wonder if it isn't the mounting adhesive causing an issue. Sealer might slow the water from going in but doesn't do anything for the moisture already there which has a tougher time getting out.
Old 08-10-2018, 02:29 PM   #4
ahlorenz@icloud.com
I will find out about the grout and sealer used and what is behind stone. I not sure what mounty adhesive means? my question is what can be done now to fix?
Thank you,
Anne
Anne
Old 08-10-2018, 02:53 PM   #5
The mounting adhesive is what was used to fasten the stones down. Do you know what was used?
You would need to replace the shower floor.
Old 08-10-2018, 03:13 PM   #6
ahlorenz@icloud.com
What is behind stone tile is mud pan tec thinset,. Grout used Mapei and sealer is Sealers Choice
Hope this helps
Thank you,
Anne
Anne
Old 08-10-2018, 03:51 PM   #7
Anne, 10-12 years ago I had to replace a shower that I had put in less than a year earlier due to the iron in the Limestone. I think it's safe to say the rust on your shower floor is from the same. Not sure about the black.
HELP! New White Ceramic Tile Faded, Rust spots & Rust On New Pebble Tile mctaino Cleaning, Restoration and Sealing 18 03-15-2013 08:31 PM
Stone shower w/mold & mildew already ?? !!! Jeraza Tile Forum/Advice Board 4 06-29-2009 10:42 AM
Rust behind my shower tile random4278 Tile Forum/Advice Board 1 10-15-2007 08:52 AM
Rust on slate tile in new shower STEVENSONMOTORS Cleaning, Restoration and Sealing 2 06-07-2007 07:32 PM
Rust stains on stone gridmeister Cleaning, Restoration and Sealing 3 01-03-2006 05:36 PM
