Unread 11-06-2012, 04:06 PM   #91
rocat1997
Ok I sure will. Mapei had told me it was. If its not, why is it so expensive then? It's almost 25 a bag compared day versabond which is 15. Do y'all have a recommendation? I'm fixing to lay 16x16 porcelain on concrete.
Roger
rocat1997 is offline   Reply With Quote
Unread 11-06-2012, 08:22 PM   #92
UF2's closest conversion to CBP is versabond flex according to my laticrete cross over sheet.
Unread 11-06-2012, 10:23 PM   #93
rocat1997
Hi Cabot, of the big box stores, what would you use to lay 16x16 porcelain on concrete? Would you use medium bed or thinset? I've gotten confused from all the choices. I still have some more flatness checks but the preliminary checks show very flat concrete.
Roger
Unread 11-06-2012, 10:40 PM   #94
For the DIY factor I'd recommend the marble medium set from home burrito over the versabond. Sure one can use versabond but there would be more wiggle room with the medium set.
If you can get your hands on some 4XLT use that.
Unread 11-18-2012, 02:07 PM   #95
rocat1997
Ok. I need some advise on installing a glass tile border in the shower. Here is some pics.
It's on a mesh. Could you guide me on the install? Thanks.
Roger
Unread 11-18-2012, 03:30 PM   #96
Make some wood blocks as shown below, The blocks (or strips) car the size of the inset plus 2 grout joints (one upper and one lower) Install the field tiles then come back for the inlay.
Unread 11-18-2012, 04:31 PM   #97
rocat1997
Thanks Cabot. What kind of tile spacers are those? I've never seen any like that.
Roger
Unread 11-18-2012, 04:36 PM   #98
Tavy spacers. They can be used as Paul is using them, or flipped around to form the intersection where 4 tiles meet each other (on a straight-lay pattern), but doing so prevents you from seeing the corners to make superfine adjustments.
Unread 11-18-2012, 05:16 PM   #99
rocat1997
The whites ones yes. What are the red things?
Roger
Unread 11-18-2012, 05:41 PM   #100
red is TLS aka tuscan leveling system. Its linked right here >>>>>
Unread 11-18-2012, 09:19 PM   #101
rocat1997
What kind of spacing would you put between the 12x12 and the glass border?
Roger
Unread 11-18-2012, 10:53 PM   #102
dhagin
For those sorts of things, we usually make the spacing close to the spacing between the glass tiles. A little bigger or smaller is usually fine too.
dana
Unread 11-19-2012, 04:58 PM   #103
rocat1997
One more question guys. How do you do the corners on the glass tile on mesh I have. Would you do the back wall first, then, overlap them with the side walls? Or would you stop both a little a head of the corner so the form a 90 on the ends? Thanks for the help!
Roger
Unread 11-19-2012, 05:02 PM   #104
The same as you would any wall, The back wall gets done first, tucked behind the side wall. If you don't lap one over the other, then caulking becomes a nightmare.
Unread 11-19-2012, 07:44 PM   #105
rocat1997
Ok thanks for the help. More tiling this weekend.
Roger
Shower project DavidHyde Tile Forum/Advice Board 19 02-01-2013 06:26 PM
Steve's Kerdi shower Project(s) (UPDATE - Uh Oh... Shower leak) LIJetsFan Tile Forum/Advice Board 75 09-21-2011 02:17 PM
Roger's Bathroom Remodel rocknroj Tile Forum/Advice Board 21 01-03-2010 01:52 PM
Shower Project help olson2334 Tile Forum/Advice Board 18 12-31-2009 11:53 PM
New Shower Project Ellron Tile Forum/Advice Board 63 04-10-2004 04:05 PM
