Unread 04-22-2010, 08:07 AM   #1
HammerMill88
tiling around a cement pond?
Howdy Folks...Hope all is well with everybody! Me?....I'm still trying to figure out what I have been doing for the last 6 months
Anyway, got a gal (same customer for whom I did shower) who wants tile around her cement pond (that would be swimming pool for u non-hillbillies!).
She wants travertine with no grout joint...other options are flagstone or sandstone.
I'm guessing an unmodified thinset, but I really would like some advice with which to advise her.
Is there already a thread to which i can be directed?
Joey
"Necessity is the plea for every infringement of human liberty; it is the argument of tyrants; it is the creed of slaves." William Pitt
HammerMill88 is offline   Reply With Quote
Unread 04-22-2010, 11:44 AM   #2
Jhereg
Signature Tile - Owner
Jhereg's Avatar
I'd fight for grout joints.
Chad N. owner
Signature Tile - Renton, Washington
www.signaturetile.net (a work in progress)
Jhereg is offline   Reply With Quote
Unread 04-22-2010, 12:25 PM   #3
e3
Wink
and a modified thin set.
Eric
Noble Company
Unread 04-22-2010, 02:53 PM   #4
a good thinset like 254.
Unread 04-22-2010, 06:51 PM   #5
HammerMill88
Yeah, I was wondering about grout joints...I'm thinking water can get in there and expand when it freezes...other reasons?
I've used 254 before, that is some sticky stuff.
Joey
Unread 04-22-2010, 06:55 PM   #6
HammerMill88
oh yeah,
there are some cracks...nothing major; and,
what about (existing) expansion joints...surely i don't want to tile over them?
Joey
Unread 05-08-2010, 12:37 PM   #7
Rtile
Randy
Are you talking about tiling the waterline of the pool or tiling the deck?
If the waterline, tell her to call a professional pool tile setter.
Indoor guys should never tile pools.
Randy
Rtile is offline   Reply With Quote
Unread 05-09-2010, 12:24 AM   #8
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Thats probably true, but I've seen some pool contractors do some crappy tile work too.
Don't use travertine as water line tile. Pool decks in travertine are ok in nonfreezing climates.
Treat the cracks with a membrane. And don't tile over the expansion joints. Put a movement joint directly over them.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 05-09-2010, 01:14 PM   #9
SP100 beta tester
EPOXY GONE WILD!
SP100 beta tester's Avatar
Rtile - "Indoor guys should never tile pools."
RUBBISH!
Indoor tile mechanics are detail orientated and use higher tech setting materials than some of the hacks that sling on pool tile.
Not saying all installers are the same but interior work is under greater scrutiny than the coping and tile of a swimming pool.
MM
SP100 beta tester is offline   Reply With Quote
Unread 05-09-2010, 10:54 PM   #10
There is a member out of Sarasota that specializes in glass pools. Jerrymir1 is is user name. He does some sweet work.
I don't think we should make dogmatic statements either way. There are unqualified people and qualified in both specialties.
That being said I generally try to avoid doing pool tile. I think the pool contractor should be responsible for the whole package.
Isaac
Maui, Hawaii
Unread 05-10-2010, 06:48 AM   #11
merkretetyler
HammerMill88,
I would suggest you push for a 1/16" grout joint at a minimum. Think of grout as protecting the edge of the tile (which can be critical with soft stone like travertine) and just being more sanitary.
My guess is if she does not want grout joints, she wants it butt tight. Is the stone square enough for that? Is the substrate flat enough? I would not suggest it.
Jim Whitfield FCSI, CCPR, CTC, LEED AP
No Longer Merkrete / Parex USA
merkretetyler is offline   Reply With Quote
Unread 05-10-2010, 04:20 PM   #12
Rtile
Randy
Ha Ha!
I knew that would ruffle some feathers.
While part of that was good old ribbing and jiving, there's a reason why I said that. I started tiling pools in Phoenix back in 84 and have intimate knowledge of all things pool tile, and an indoor guy may be able to do a fine job if he is one of us conscientious setters, but even then there are things that indoor guys just don't know about. And they're set up for pools. pool scaffolding and such. You may get through it, but not like I'd do it. Same as a pool setter with no indoor experience would be. Tricks of the trade and all that you know. Plus, the pool guy should be a serious mud master, since he does nothing else but mud work underneath his tile.
Anyway, not really trying to start a feud, just saying.
Also, sounds like the OP is talking about the deck, so my point is moot anyway. Surely no one would consider travertine on the water line. specially with no grout.
TBH, travertine on a deck with no grout might be a little too.
Randy
Tiling over cement Randy Malm Tile Forum/Advice Board 3 04-16-2009 06:15 AM
tiling on new cement jwyman Tile Forum/Advice Board 4 04-30-2007 09:09 PM
Pool/Pond height extension and tiling Peterg Tile Forum/Advice Board 2 01-06-2006 10:22 AM
tiling over cement gohikingprn Tile Forum/Advice Board 3 01-03-2006 02:43 PM
Tiling on Cement . . .? t_wall Tile Forum/Advice Board 1 01-05-2003 08:43 PM
