Unread 10-07-2009, 01:00 PM   #1
qzrrbz
Ditra and 2" hex carrera marble?
Doing a bathroom remodel on a 1900's house. Nothing square, hills, valleys, sigh...
Looking at the Ditra product to go under wife's chosen 2" across hexagonal ~ 3/8"+ thick carrera marble mesh sheeted tiles. It seems that that product would be much happier used with big 12" square tiles. is that an accurate assessment. I have bought 1/2" hardibacker to try to flatten out my world a little. Is this a more recommended idea?
Any other better ideas out there?
qzrrbz is offline   Reply With Quote
Unread 10-07-2009, 01:07 PM   #2
Jason_Butler
Tile Setter
Use the Ditra - just install the Ditra and fill all the waffles on Day 1. You can tile on Day 2.
This method will ensure the small tiles don't fall into the waffles
Jason
Unread 10-07-2009, 01:11 PM   #3
Pete1972
Jack of all trades, master of none
Pete1972's Avatar
D'oh! Just logged in to write what Jason wrote. I used Ditra under a mosaic carrara marble basketweave and contacted Schluter directly and they said the same - lay Ditra, skimcoat top of Ditra with thinset and let dry for 24 hours, then tile. Mine has worked out well so far.
Pete1972 is offline   Reply With Quote
Unread 10-07-2009, 01:11 PM   #4
SyTile
Take a look at the Ditra installation handbook, page 8. They have specific notes for natural stone. http://www.schluter.com/media/brochu...raHandbook.pdf
Travis Johnson
Syverson Tile & Stone
SyTile is offline   Reply With Quote
Unread 10-07-2009, 02:16 PM   #5
qzrrbz
Thanks for the replies!
I've gone off and read the Ditra handbook install notes on the Schluter site. It would seem that the thinset that I already have is not recommended?
I have what I trust to be "modified" thinset: Superior's Pro Flex Platinum "Latex Fortified Thinset Mortar", least that's what I can read off the bag. (sold by the Tile Shop)
Is this useful here? Which layer? Floor - Ditra or Ditra - Marble? Any advice?
Unread 10-07-2009, 03:49 PM   #6
qzrrbz
When in doubt, call the manufacturer and ask!
Got off the phone with Schluter. Their recommendation was ...
1) OK to use *modified* thinset between subfloor and DITRA.
2) NOT OK to use *modified* thinset between DITRA and tile.
So, off to the store I go for a different bag of stuff!
As far as hex tiles, 2" is as small as they would suggest going, and then "fill in the (waffle) blanks first", as had been suggested a couple times by guys who know what they're doing above!
Unread 10-07-2009, 03:53 PM   #7
Rd Tile
Tile Man
Rd Tile's Avatar
Can't see why you can't pre-fill with modified, no tile going over it, should cure fine.
But what do I know, been using Versabond under and over for years now, no issues, carry on.
Richie.
Unread 10-16-2009, 05:31 PM   #8
qzrrbz
Weekend warrior back at it again. Gotta keep the day job... :-)
This DITRA stuff is seriously great to work with. Although it is a serious ring-tailed b*tch to move once set down. The idea of sliding a piece under cutout jambs and whatnot isn't a real good one, especially if it's a *big* piece!
Other than that, so far so good!
RandyD -- enthusiastic tile n00b
Is Uncoupling necessary? Ditra, 1" hex woes crysbis Tile Forum/Advice Board 17 01-29-2008 01:41 PM
Please help problems with carrera marble lcornell Tile Forum/Advice Board 1 09-30-2007 01:50 PM
12" carrera marble flooring bridgeport07 Tile Forum/Advice Board 1 02-18-2007 10:40 PM
Carrera marble saddle Maack Professionals' Hangout 1 10-06-2006 06:08 AM
Grout for Carrera Marble May Tile Forum/Advice Board 3 09-22-2004 07:00 PM
