Unread 05-17-2009, 07:56 PM   #1
HammerMill88
DensGuard Tile Backer
Say,
What do you guys know about DensGuard (same as DensShield?) made by Georgia Pacific? I have seen it at Lowe's and have seen a local contractor use it in showers - though he did not tape the joints.
Would it be a good substitute for Durock?
Joey
"Necessity is the plea for every infringement of human liberty; it is the argument of tyrants; it is the creed of slaves." William Pitt
HammerMill88 is offline   Reply With Quote
Unread 05-17-2009, 08:30 PM   #2
tilerite
tilerite's Avatar
This thread covered the topic of DensGuard and DensShield
http://www.johnbridge.com/vbulletin/...ight=densguard.
tilerite is offline   Reply With Quote
Unread 05-17-2009, 08:47 PM   #3
Joey,
You can't bury the bottom of this board in your mud pan. The install detail the manufacturer shows to "install it correctly" in a shower with a mud pan includes the extra task of mudding the lowest several inches of the walls.
Unread 05-17-2009, 09:04 PM   #4
Deckert
I think Densguard works pretty good for tub surrounds. I did all the seams, and where it meets the tub in SikaFlex. Tape and thinset like normal backer ( I did it as we set the tile). Never used it in a shower though.
Brannigan
HeenanGC.com
Unread 05-17-2009, 09:12 PM   #5
HammerMill88
The literature - Installation Instructions- I have in my hand (from a piece of DensGuard) only showed it being used with a prefabbed shower pan and then caulking the joint where wall tile meets pans. They do say "Do not place in shower pan mortar bed. Leave minimum 1/8" gap and fill with flexible sealant." Literature also says to fiberglass tape and thinset the joints.
The website they give is
www.gp.com/build or 1-800-225-6119
Another misleading thing about the Instructions, is that they do keep referencing the grey acrylic coated side. I guess it was too expensive to edit the literature.
I noticed in the previous thread L.T. recommended maybe running the first foot or so with Durock. I question that, b/c I backed a tub surround where I wound up using a strip of Durock around 13" wide x 32" long with studs 16" O.C. and it seemed a little flimsy. I would either use a whole piece, if running it horizontally, or block smaller pieces of Durock (or any backer narrower than say 24") at the joint. The other option would be studs 12" O.C. I guess, but that may be overkill.
Joey
Densguard Odor tslayer Tile Forum/Advice Board 71 10-16-2015 10:10 AM
Densguard--the bottom line custombuilt Professionals' Hangout 9 07-16-2008 04:52 PM
Q re: Densguard & liner GoldIngot Tile Forum/Advice Board 2 06-29-2008 01:49 PM
DensGuard odor revisited Alto Professionals' Hangout 2 06-12-2008 05:59 PM
Densguard vs CBU wmw Professionals' Hangout 7 02-04-2004 07:00 PM
