Unread 01-21-2022, 11:13 AM   #1
wzhao
Walls not flat problem
I am tiling the shower walls and right now am about to apply schluter kerdi membrane on top of drywall. I already made the mistake of having drywallers apply tape and joint compound to all the seams so I ended up priming the whole surface. I had confirmed with schulter that it would be fine to install kerdi membrane on primed drywall as long as it was latex primer. So I guess I'm good on that issue.
Now when I am checking for flatness of the walls, I realized that the back wall of the shower has a vertical hump right in the middle of it. I'm guessing that the waste pipe that was installed was sitting just a bit proud of the rest of the studs causing this hump. I think it might be sticking out around 1/4inch out.
How can I solve my problem?
Can I simply apply thinset to the wall in all the low places until it is all on the same plane. Let the thinset harden and then install kerdi membrane with more thinset?
Or should I go ahead and install kerdi membrane on the wall first, then when tiling, slap on more thin set in the low spots to bring the tiles plumb.
Is thinset the right material to use for this or should I use some drypacked mortar?
Any thoughts?
Wing
wzhao is offline   Reply With Quote
Unread 01-21-2022, 11:41 AM   #2
Welcome, Wing.
What you really want to do at this point is remove the drywall, correct the problem by moving the offending pipe (if that's what you've got) or furring out the studs such that your new drywall lies flat when installed.
You really, really don't want to try to flatten the tile installation while setting the tiles. Nor would you want to use thinset mortar to flatten a wall to that extent, or any extent, technically. There are patching compounds suitable for the application, but that's an excessive use of such material to my thinking when the wall can be corrected otherwise. And I think you'll find you can replace the drywall more easily in this case than you can plaster the existing wall flat.
How picky to be about having flat backboards on shower walls? rvbissell Tile Forum/Advice Board 14 04-21-2019 08:13 AM
Best ways to fur out walls to get them flat and plumb for tile? tileman1986 Professionals' Hangout 42 03-09-2016 12:46 PM
Bathroom walls not flat gspman Tile Forum/Advice Board 3 03-23-2006 06:10 PM
out of plumb and non flat walls kevjob Professionals' Hangout 1 01-14-2006 02:23 PM
best way to tell if floor is level/flat-and other flat surface issues!? acid Tile Forum/Advice Board 9 05-12-2005 10:32 PM
