Unread 01-13-2022, 03:38 PM   #1
Lou_MA
Patching slab around drain
Looking to patch a trench in this 3” thick slab.
My plan is to shovel in some damp sand until it’s level with the bottom of the slab, tamp it down, paint some loose thinset onto the sides of existing slab and immediately fill hole with concrete for a flush patch. Let dry, then do a bonded mud bed.
Is that approach correct?
Do I need to add rebar or any other kind of reinforcing to tie old and new together?
Lou
Unread 01-13-2022, 04:35 PM   #2
A three-inch field in a SOG foundation? Youins Yankees do some weird stuff, Lou.
Doesn't look like there was any reinforcing steel in that slab before you cut into it, so there wouldn't be anything to match. I like re-bar in my slab repairs, or at least some re-bar dowels into the sides of the hole, but in your situation, that might be overkill. Your sides look rough enough that just bonding your patching concrete mix with a bit of thinset mortar might be good enough.
a few questions: patching slab, handling window, etc. TTorrey Tile Forum/Advice Board 6 08-26-2012 04:56 PM
Cement Slab Patching Before Tiling richris Tile Forum/Advice Board 3 10-03-2006 04:17 PM
Something different: concrete slab hole patching RichTile Professionals' Hangout 6 06-06-2005 01:50 AM
patching concrete slab CharlieM Tile Forum/Advice Board 3 03-29-2005 08:54 AM
patching slab nick001 Tile Forum/Advice Board 4 03-30-2003 03:08 PM
