Unread 01-12-2022, 07:08 PM   #1
Timbo78
Large Format Porcelain
Hi everyone- I'm installing some 48"x48" Porcelain tile. I'm using a snap cutter and having a problem with the very top of the cut chipping. The rest of the cut is absolutely perfect but I can't seem to figure out how to prevent the top from chipping. Any ideas other than finding someone with a bridge saw? Thank you!
Tim
Timbo78 is offline   Reply With Quote
Unread 01-12-2022, 09:10 PM   #2
Hi, Tim.
What snap cutter are you using?
Unread 01-12-2022, 10:40 PM   #3
Timbo78
I believe it's the CO-Z
Tim
Unread 01-13-2022, 12:14 AM   #4
Is the cut consistently veering off to the same side?
I’d ask the usual questions about having a sharp scoring wheel and if the bar is sliding very freely, but I’m going to guess this is a new tool in perfect shape…and is sliding smoothly. If so…
Fairly often, it takes a pretty high quality snap cutter to snap tiles cleanly. It may be that you need the extra precision from a higher dollar tool to cut cleanly all the way across. Sigma is one such brand that is famous for cleanly snapping tough porcelains. I’ve never used your brand saw. And I’m not a tool snob. I’ll use whatever works, irrespective of its cost. But your tool is only 1/7th the cost of the Sigma. So, you might have to be satisfied that your tool is doing the best it can.
Unread 01-13-2022, 07:29 AM   #5
Timbo78
Yeah, that makes some sense. But the reason I'm wondering if there's some technique I'm missing is because the rest of the cut is laser-perfect. Indistinguishable from the factory edge. So the scoring wheel is good so I'm wondering (given the fairly simple physics of the tool) what could be different in another higher-end model?
Tim
Unread 01-14-2022, 01:07 PM   #6
Tile & Stone Guild
King Of Tile
Cutters with the rubber pads like that will have a hard time with a large format that isn’t ceramic. You need to spend close to 1k or more to get a quality cutter that will reliably cut most tiles.
Jeff
Unread 01-14-2022, 01:44 PM   #7
Tile & Stone Guild
King Of Tile
Larger cutters the spline stands proud and the piece will teeter slightly, some things need brute force also.
Jeff
Unread 01-14-2022, 01:57 PM   #8
This was a while ago...when someone was demonstrating cutting a large format tile, they put the cutter in a bit, and pushed it off of the end rather than starting at the outside, and cutting the whole thing in one swipe.
Maybe someone can verify that. The tile can get expensive, so experimenting may not be something you want to do, but if you have one you can't use any more, try that. It may have been specific to that particular cutter...I do not know if it is a generic thing that might work on various designs.
Unread 01-14-2022, 04:34 PM   #9
Lazarus
Lazarus's Avatar
I use and like my Ishii cutter. Mine will not go 48" but I do generally "backcut" about an inch before doing the major score, as you can see in my video. Not sure if the chipping issue you have is here or on the top. A good quality tungsten wheel also is essential....
https://www.youtube.com/watch?v=LTX8DtndtvQ
Laz...
A man who carries a cat by the tail learns something he can learn in no other way.
Unread 01-14-2022, 04:50 PM   #10
Lazarus
Lazarus's Avatar
Another review...
https://www.youtube.com/watch?v=NohqaEdtcSI
Laz...
Unread 01-14-2022, 04:53 PM   #11
Lazarus
Lazarus's Avatar
"Sigma" is another great cutter. Here is a review with the Sigma vs the Ishii.
https://www.youtube.com/watch?v=laWgt6FYIcQ
Laz...
Large format porcelain over Durock memberane? srii Tile Forum/Advice Board 16 06-23-2019 05:49 PM
Unmodified for large format porcelain? hhcibtpaun Tile Forum/Advice Board 4 10-16-2018 06:04 AM
kitchen retile w/large format porcelain inorkuo Tile Forum/Advice Board 16 08-24-2012 01:57 PM
Installing Large Format Porcelain Tiles Phildro Tile Forum/Advice Board 27 11-30-2007 08:04 AM
Is All Porcelain PEI-5 Large Format Created Equal? TTTTttt1 Professionals' Hangout 5 09-09-2006 05:28 PM
