Unread 02-21-2016, 12:36 AM   #1
KMPBooker
Installation Advice?
1930s house. Professional removal of asbestos tile in basement complete. (Carpet was glued directly to the tile so both had to go.) Floor is concrete with minimal hairline cracks. Occasional, minimal water during very heavy rains in the spring. Wanting to install ceramic tile in this area.
Is it necessary to put anything between the tile and the concrete floor, other than thin set?
KMP
KMPBooker is offline   Reply With Quote
Unread 02-21-2016, 06:41 AM   #2
Peerless Tile
Tile Contractor
Tape (seal) a small sheet (about 1 sq ft)of plastic to the concrete and let it be for 24hrs minimum to see if there is any presence of moisture coming up through the slab. advise us of the results, and we'll try to put you on the correct path.
Typically I would use something like ditra in your application. It aids in many ways. Check it out for yourself. Some added piece of mind in my eyes.
http://www.schluter.com/schluter-us/...TRA-XL/p/DITRA
SC Greg
Peerless Tile is offline   Reply With Quote
Help: Need advice on tricky installation oldhomeowner Tile Forum/Advice Board 7 03-11-2012 06:27 PM
Shower installation advice G Archer Tile Forum/Advice Board 34 12-10-2010 06:24 PM
Bath Installation Advice sbmarcovsky Tile Forum/Advice Board 17 11-12-2009 01:05 PM
Need advice on an installation. enviroko Tile Forum/Advice Board 9 07-26-2007 04:00 PM
need advice on membrane installation lescon Tile Forum/Advice Board 6 07-18-2006 08:49 PM
