Unread 11-02-2015, 08:47 AM   #1
theeld
Insulation Interior Walls - Tile Shower
In general, I am a fan of insulating interior walls for purposes of sound transmission. We are redoing a full walk in shower, and am curious if anyone has opinion as to whether insulating the adjacent walls in the shower is a BAD idea, or if I should have any reservations putting unfaced fiberglass insulation in the interior walls. One wall is exterior and is obviously insulated with moisture barrier. Shower will be installed with kerdi membrane/denes shield.
Opinions will vary about insulating walls for sound transmission, but I feel it small cost in comparison, just curious about opinions on any issue specifically in this application, thanks!
Lyle
theeld is offline   Reply With Quote
Unread 11-02-2015, 09:47 AM   #2
This a project for which we already have a thread, Lyle?
I have always installed unfaced fiberglass batt insulation in all bathroom walls that are shared with living space, regardless whether the walls be part of the shower. It's cheap, fairly effective, and just makes a better house.
Unread 11-02-2015, 11:29 AM   #3
matthewstephanie
I second that opinion. The 2 bathrooms I redid, the insulation has been effective in reducing noise in neighboring rooms. One shower/tub is adjacent to the kitchen, and you cannot even hear the shower running.
Matt
matthewstephanie is offline   Reply With Quote
Unread 11-02-2015, 07:54 PM   #4
Jaz
Michigan Tile Pro
Jaz's Avatar
Lyle,
I like the idea of insulating the walls too, but regular thermal insulation does not reduce the sound much. You need insulation made for that purpose. It's available everywhere.
I'm more concerned about your statement .....
(DenShield)
I'm not sure I like that combo. I would skip the Dens and go with real concrete backer or do what Schluter recommends and use regular wallboard. Or, Kerdi Board.
Jaz
Custom TileSetter (retired)
Method & Product suitability consulting
marmo.sicilia@yahoo.com
Unread 11-02-2015, 08:13 PM   #5
Jaz is correct. The thinset mortar between Kerdi and Densshield would take a very long time to dry, since both of those materials are impervious to moisture. Not to mention, you'd be wasting your money with a double vapor barrier.
insulation around copper pipes interior wa jeeper Tile Forum/Advice Board 3 02-10-2014 04:13 PM
Fiberglass insulation on interior wall Eggie Tile Forum/Advice Board 12 05-07-2013 09:09 PM
Interior Bathroom Shower Walls sky Tile Forum/Advice Board 13 01-20-2009 10:44 AM
Insulation on interior wall behind Kerdi? kesslerou Tile Forum/Advice Board 3 02-27-2006 01:24 PM
Removing interior loadbearring walls projetpilot Professionals' Hangout 13 07-14-2001 05:22 PM
