Unread 02-12-2011, 01:42 PM   #1
laurie_ds
is it possible to clean stained granite?
I have a problem with my granite countertops. We have a cooktop that is set into the granite and the cutout for the cooktop was done by the installers at the house. The installers spoke almost no English--I think they were Polish. The head installer spoke a little English, and when he left he said something about how we would have to seal the granite. I assumed he meant that in time we would have to reseal it, which I had already heard about. He didn't make clear that the edge around the cooktop that was freshly cut would have to be sealed. Well, that edge has now had grease or moisture soak into it, probably because liquids seaped under the cooktop, and there is a darkish stain around the area but the stain is within the granite. The granite colors are dark yellow/orange/brown/red and at first I thought it was my imagination that some of it looked darker, but now it's noticeable and it is clearly a stain. Is there anything I can do to clean it before sealing it off so it doesn't get even worse? I've purchased sealant for stone, but I'm hoping there might be something I can do first to clean it.
Thanks! --Laurie
Laurie
laurie_ds is offline   Reply With Quote
Unread 02-12-2011, 02:06 PM   #2
Brian in San Diego
Brian in San Diego's Avatar
It is possible, but much depends on how stained the stone is and what caused the stains. I am not even a novice in this area, but there are stone care websites that these types of questions are routinely asked and answered. I do know that a poultice is often recommended.
Unread 02-12-2011, 02:16 PM   #3
Davestone
Florida Tile & Stone Man
It is probably beyond the point you could clean it.Granite can be seriously stained by oily substances.If a degreasing cleaner,even Joy works,doesn't work, then a poultice doesn't work, call a resto type guy maybe he can use a flame to get the rest out.Don't use bleach.
http://Davestonestile.com
Unread 02-12-2011, 03:06 PM   #4
laurie_ds
Thanks for your responses. I'm thinking it's probably not going to be possible to clean this, but I'll try. So, say I do the best I can do but it doesn't get much better, should I go ahead and seal it as is to prevent it from getting worse?
laurie
Laurie
Unread 02-12-2011, 04:20 PM   #5
Trask
Oregon Tile Man
Trask's Avatar
Laurie,
You can pull almost anything out of natural stone if you have the time and knowledge. A seasoned restoration pro will have an awesome bag of tricks..but I'd try this first.. I 've drawn some pretty deep stains out with this:
http://www.galaxytoolsupply.com/Ston...nce-p/8055.htm
Very user friendly ..Just read the directions
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 02-13-2011, 07:39 PM   #6
graffster
graffster's Avatar
Hay Trask, hows it going it's been awhile. The stain can be removed with Bellinzoni Mangia Macchia it might take a few applications depending how bad it is. I have had good luck using this product so like pulling blooms.
George M. Graff S.F.A.
Stone Pro Restoration & Repair
Boise, Id
Cell 208-284-3984
Fax 208-853-2793
graffster is offline   Reply With Quote
Unread 02-14-2011, 09:56 AM   #7
Trask
Oregon Tile Man
Trask's Avatar
George..Good to see you here.
Don't be a stranger we need more folks like you with restoration time under their belts.
Trask Bergerson
Astoria, Oregon
Unread 02-14-2011, 04:10 PM   #8
StoneTooling
Vending Machine
StoneTooling's Avatar
We sell the Bellinzoni too and it is a great product. I wouldn't hesitate to try a poultice as it requires little work and you can buy it cheap: http://www.aquamixdirect.com/servlet...tain%2C/Detail
Let us know what works for you and good luck on removing that stain!
Lauren V.
StoneTooling Now shipping internationally!
Visit us and purchase through the sponsored link at the bottom of the page to support the JB forums!
Contractors - send us your information to be listed on our contractor page.
StoneTooling is offline   Reply With Quote
granite stained tilelayer Cleaning, Restoration and Sealing 36 12-02-2008 05:00 PM
How to clean silicone from granite Mwalt Cleaning, Restoration and Sealing 6 08-21-2008 10:53 PM
How to clean stained marble? DJMAHE19 Cleaning, Restoration and Sealing 1 06-01-2008 09:09 PM
clean/sanitizing granite ry91 Cleaning, Restoration and Sealing 3 10-13-2006 03:29 PM
water stained granite tile victord Tile Forum/Advice Board 2 04-09-2006 07:32 AM
