Unread 12-30-2014, 05:59 PM   #1
SusieG
Granite stained by soap
Hi all,
I made the mistake of setting a soap dispenser on my brand new granite countertop before I sealed it. Left a slightly darker ring, ugh! I've contacted Simple Human (soap manufacturer) to find out if they know how to clean, but after two days, they have only managed to refer me to a senior level tech, but no answers. I know you all will have a quicker response.
Susie
Susie
SusieG is offline   Reply With Quote
Unread 12-30-2014, 06:08 PM   #2
SusieG
Another pic
Here is a close up picture of the stain.
Susie
Unread 12-31-2014, 04:27 PM   #3
doitright
doitright's Avatar
Hi Susie
There is no easy sure fire way to remove the soap stains. Depending how deep the stain is set will determine how many applications of a poultice will need to be applied.
You could do a TEST with Acetone and white non print paper towels. Acetone is extremely flammable! Please use caution and keep away from all open flames and sparks.
Cover the stain completely (overlapping at least 1" in all directions) with at least the equivalence of 1/2" of the paper towel and saturate with the Acetone. Cover with a piece self stick plastic wrap. Allow to sit over night. In the morning remove the plastic. Allow the paper towel to thoroughly dry out before removing.
After removing the paper towel, assess the stain. It's possible that the darkened area is larger. If that's the case, allow it to dry out.
Has the stain remained the same, diminished, or disappeared altogether? If it has diminished you can repeat the process. This may take several applications. Allow the stone to dry thoroughly between applications.
John Koessler
Unread 01-08-2015, 09:12 PM   #4
SusieG
It is much lighter now
Thanks so much for the help. It did help, and is not nearly as noticeable. Appreciate your expertise!
Susie
Unread 01-08-2015, 09:16 PM   #5
doitright
doitright's Avatar
Hi Susie
That's great news!
Thanks for reporting back!
John Koessler
Unread 01-08-2015, 10:12 PM   #6
jontillman
jontillman's Avatar
If you have any other issues with this, I would also recommend a poultice. I have found that a simple mixture of baking soda and bleach will also work, but may take a few applications. I would also recommend a high quality natural stone sealer to further protect your investment. I believe my fellow poster got you on the right track and hopefully you won't have any more issues!
ya jus' gon have that on them big jobs!
Jon
jontillman is offline   Reply With Quote
is it possible to clean stained granite? laurie_ds Cleaning, Restoration and Sealing 7 02-14-2011 04:10 PM
Liquid soap stained grout? Tat2d Cleaning, Restoration and Sealing 24 02-23-2010 09:12 PM
granite stained tilelayer Cleaning, Restoration and Sealing 36 12-02-2008 05:00 PM
water stained granite tile victord Tile Forum/Advice Board 2 04-09-2006 07:32 AM
Soap stain on Granite rorban Cleaning, Restoration and Sealing 2 08-24-2005 01:31 PM
