Unread 07-27-2021, 10:43 AM   #1
Michos
Tricky tile removal/replacement
I need to cut a small piece of discolored tile from a larger section at the entrance of a shower floor. Ive attached an image. Im unable to cut along the grout lines on either side because, as you can see, the tile runs underneath the glass which cannot be removed at this time. Im wondering if anyone has ideas on a tool I may use to get a clean cut on either side of the discolored section. Obviously an angle grinder is only going to be able to cut so far down before damaging the tiles on either side. Im thinking that an oscillating multi-tool could work but im concerned that the standard bit for removing grout is going to have a hard time going through that much material and will not be so precise. Any ideas on what tool, bit and/or method I should use? Of course, to complicate the issue, im sure that there is a shower pan underneath the tile so I will need to be extremely careful not to damage it.
Michel
Michos is offline   Reply With Quote
Unread 07-27-2021, 04:31 PM   #2
I would wait till the glass can be removed. No way would I cut and pry on any part of the curb/saddle with the glass in place. Then, if possible, I would want to have some extra marble and mosaics before starting. Knowing what type of pan was used would be helpful. Something needs to be done but I'm sure you realize you could be opening a big can of worms.
Unread 07-27-2021, 04:34 PM   #3
Just In Tile LLC
Just In Tile LLC's Avatar
I second Davy on can of worms, all the modern systems don't play well with isolated removal.
Justin
Very tricky sink replacement. Should I try to tile it again? djxpress Tile Forum/Advice Board 1 11-28-2019 09:21 PM
tile removal and replacement Dreuxgrad Tile Forum/Advice Board 5 01-17-2014 09:58 AM
Tile countertop removal and replacement dansal Tile Forum/Advice Board 49 11-13-2013 04:11 PM
Bath tile removal and replacement Mike DIY'r Tile Forum/Advice Board 6 06-24-2009 02:50 PM
Grout removal and replacement nonstopaz Tile Forum/Advice Board 15 09-22-2005 07:14 AM
