Unread 07-29-2021, 05:30 PM   #106
Stand back and look at it. If it's noticeable to your eye then you might want to change it. It's possible that it might become more noticeable as you install more tiles.
Unread 08-02-2021, 09:36 AM   #107
xkse
Thank you for the advice. I removed the tile and replaced the section of membrane instead of trying to save it as it had pulled the membrane away from the cbu in some spots and I didn’t feel like grinding down all of the extra thinset mortar.
Nick
xkse is offline   Reply With Quote
Unread 08-11-2021, 05:37 PM   #108
xkse
Layout Advice
Hoping for some thoughts on layout...the 'gray is the back wall and bench. I've put my niche so that it lines with a grout line and is a tile high. With the 12x24 and a 1/3 stagger, i've come up with the following 4 options.
  • If I center it underneath and above the niche and double stagger them, then there will be a 4" piece on the side of the niche to keep the pattern (pic 1)
  • Triple stagger with center under the niche (pic 2) leaves the same 4" piece, but an offset above the niche
  • Triple offset, non-centered above/below the niche, leaves larger pieces next to the niche but smaller ones along the edges
What is the smallest non-whole piece you would want, and what are your recommendations for layout ? If I want to wrap it around and continue the pattern to the walls on the left and right sides, is there a point where I should just start with a whole new tile instead of using a small piece?
Nick
Help! New curbless linear drain shower april lau Tile Forum/Advice Board 36 10-28-2019 07:11 AM
Eric's linear drain shower? EricO Tile Forum/Advice Board 29 11-05-2017 09:21 PM
Linear drain shower - CBU over subfloor? stephenson Tile Forum/Advice Board 57 09-06-2014 02:01 PM
Linear drain at shower entry Creative Construction Tile Forum/Advice Board 32 11-15-2012 11:17 AM
New shower with linear drain Bronco Guy Tile Forum/Advice Board 4 03-10-2011 03:29 PM
