Unread 08-28-2012, 12:13 PM   #1
jimling
Sub Floor Thickness
Hi All,
I have been reading some thread's on this great forum and would appreciate some advice.
I am tiling a kitchen (8x10) and after reading "the internet...." I am unsure how much plywood to add to ensure proper thickness of sub floor. The existing 5/8" is in good shape and my plan was to add 1/2" and then the tile directly onto that. Is my plan sound?
Thanks for the help.
Jim
Jim
jimling is offline   Reply With Quote
Unread 08-28-2012, 12:58 PM   #2
Assuming your joists are strong enough for the tile in question, there is an approved method of installing tile directly on two layers of plywood, but most people much prefer using a different method!
Technically, if the 5/8" ply is T&G, it meets the minimum industry spec for tile with a decoupling layer as it stands, but that means it is new, and in perfect shape which rarely happens so more ply is better.
The minimum additional ply you'd want to add would be 3/8", C-faces or better, exposure 1 or exterior rated glue, properly oriented and anchored. More is fine.
To tile directly on ply requires a quite expensive, highly modified thinset. Most people use cbu and then install the tile to it. An alternative, should you wish to keep the height down, is a membrane. One I've used and like is Ditra from www.schluter.com. Technically, that could be installed directly over the ply you have now - if it is in perfect shape.
Floor thickness aroccos Tile Forum/Advice Board 2 10-05-2006 08:36 AM
Mud floor thickness Willdapill Tile Forum/Advice Board 16 03-23-2004 06:59 PM
sub-floor thickness kev Tile Forum/Advice Board 13 02-22-2004 08:40 PM
floor thickness zep Tile Forum/Advice Board 2 06-06-2002 04:01 PM
What thickness to use as sub-floor. Stephanie Tile Forum/Advice Board 6 05-22-2002 10:50 PM
