Unread 01-21-2003, 11:02 AM   #1
Floor tiler
Guest
Posts: n/a
Thermal Insulated Board
am installing “Warmly Yours” electric floor heat in my bathroom. They recommend a Thermal Insulation Board on the floor. Has anyone heard of this backerboard or worked with it before? If so, where can I purchase it?
(They want in on the floor because underneath the floor is a dirt crawl space and they claim it will prevent heat loss)
Unread 01-21-2003, 11:14 AM   #2
e3
I have not read there dierections but they most likely mean somethimg like styro foam to insulate the floor. Are they calling out for a mud bed over the board?Or do they want it between the joist?(Below the floor)
Eric
Noble Company
Unread 01-21-2003, 11:28 AM   #3
Floor Tiler
Guest
Posts: n/a
They call for subfloor (1" thick), thin set, thermal insulated board (1/4" thick), electric floor mat, thin set and tile.
Unread 01-21-2003, 11:45 AM   #4
e3
Not sure what they are doing-- There are some boards out there that have a foil reflector laminated to them used under mud bed applications- I see it most often with hydronic !
Eric
Noble Company
Unread 01-21-2003, 11:48 AM   #5
Garrett
Have you called or emailed the company to see what they are talking about?
Pete
"There is nothing common about common sense."------Voltaire
Garrett is offline   Reply With Quote
Unread 01-23-2003, 12:25 PM   #6
Floor tiler
Guest
Posts: n/a
I contacted the company and they said the product is Wedi
board which is a foam backerboard with r values. Has anyone used this product?
Unread 01-25-2003, 01:41 PM   #7
Hi,
I'm not a radiant heat guy, but wedi is a styrofoam board that is a tile backer. I've not heard of it being installed over thin set. Maybe you could find something on their site.
http://www.wedi.co.uk/flash.htm
