Unread 07-23-2019, 10:13 PM   #76
Do you wear gloves?
Unread 07-23-2019, 10:56 PM   #77
thuffner3
Straight Coka Cola
Neil Jackson, from Cincinnati, Ohio
Her contractor said she could have it installed today.
thuffner3 is offline   Reply With Quote
Unread 07-24-2019, 09:39 AM   #78
CaliGrown
CaliGrown's Avatar
Shawn, I do occasionally when I have heavier days. I’m a cheapskate when it comes to taking care of myself though, quality setting materials over safety glasses and gloves. I did finally get dust shrouds and respirator masks.
Christopher Machado
1 (916) 990-1751
Unread 07-24-2019, 11:04 AM   #79
Chris, nitrile gloves will be your best friend and well worth the money. And if you were really pinching pennies you could reuse them if you didn't rip them on the previous day. Don't buy the cheapest ones you can find the are turds and not even worth using. My mom gave me some, no idea where she got them but they were thin and ripped just putting them on. I threw them away because they were so frustrating that I didn't even want them as a back up
Unread 07-24-2019, 02:53 PM   #80
KiwiTiler
I find 14 mil latex gloves to be a bit better, nitrile for chemical handling and latex for general use.
Even the heavy duty nitrile don't last long enough
Wouldn't recommend no gloves, only a matter of years or the wrong thinset before any cement contact will cause dermatitis. Cement is a sensitiser, the more contact, the greater the chance of an allergy.. Sigh
Mark
Mark
KiwiTiler is offline   Reply With Quote
Unread 07-24-2019, 04:11 PM   #81
jerrymlr1
Thickster gloves on Amazon
Unread 07-24-2019, 06:54 PM   #82
I have used these for longtime. I get them tight so I can really feel what I am doing
https://www.ansell.com/us/en/product...eno-ec-sec-375
Unread 07-24-2019, 08:00 PM   #83
I'm all about those 5 mil gloves from harbor freight, 7.99 for 50 then bust out a 20% coupon.
Unread 07-26-2019, 09:45 PM   #84
When you get into crazy shaped tiles, like these fish scales, cut a thin plywood jig or two to use on the tile saw. This way you can keep the cut square with the layout of the pattern.
Unread 07-27-2019, 05:48 AM   #85
PC7060
PC7060's Avatar
How did you cut the curves Davy?
Unread 07-27-2019, 06:09 AM   #86
We cut the curves in the plywood with a jig saw.
Unread 07-27-2019, 09:40 AM   #87
PC7060
PC7060's Avatar
Davy, I’m sorry, I was thinking you also cut the tiles to that shape too. Wondering how you got such smooth finish.
Unread 07-27-2019, 11:41 AM   #88
No, I didn't make the tiles. They came from Ann Sacks this shape.
Unread 07-27-2019, 04:26 PM   #89
KiwiTiler
Water jetting achieves similar finishes, if ever asked :-)
Mark
Mark
Unread 07-30-2019, 06:52 PM   #90
The pros will know this but in case a DIY'er shows up, nearly all patterns repeat in the layout. With a small backsplash, I would probably free hand most of this pattern but I have about 200 sq ft to install in a shower and on bath walls. I like to mark lines to keep me consistent.
making and tiling a half column bender123 Tile Forum/Advice Board 9 06-10-2010 09:52 AM
Another Hack Job HS345 Professionals' Hangout 35 02-24-2009 10:26 PM
An easier way! mmoore Tile Forum/Advice Board 22 12-11-2008 09:07 AM
What a hack job. muley Professionals' Hangout 13 03-07-2007 01:06 PM
Hack job Northwest Tile Guy Professionals' Hangout 19 12-09-2006 06:57 PM
