Unread 09-04-2010, 03:09 PM   #1
scott anthony
Tile Man -- Central Florida
scott anthony's Avatar
back splash switch outlets
I completed a job last week for a feller that has an issue. Before I start this job took a week to do and was one of the toughest pain in the ars's we had in while, hopscotch diagonal 800 + with a backsplash where the glass was 1/8th and the tile was 3/8 thick. We got it level and it came out fine and everyone was happy as a clam, I didn't know clams get happy but it all went like planned.
A few days after the job was done we get call he wants to have a piece of tile under the back side cabinet void filled until it could no longer be seen from his knees I guess, NO PROBLEM. We went out and completed the ten minute fix, BUT while we was there he was doing his own inspections and found we used a drywall screw to replace the existing switch screws due to the reach, you know. He was having a fit and was very upset that we did not use a machined screw for this. I have done 100's and never have had this issue, all of what we did in that guys house and all he could find is that. There was no telling him it was just fine, there was no reason for that application to be used in our industry.
I am not really looking for a answer here I'm just sharing a thought and experience, it's done and he will live with it I guess.
Scott
scott anthony is offline   Reply With Quote
Unread 09-04-2010, 03:25 PM   #2
Wayne67vert
Tile Contractor
Wayne67vert's Avatar
Send a message via AIM to Wayne67vert Send a message via MSN to Wayne67vert Send a message via Yahoo to Wayne67vert
He must be an Engineer!
Wayne
Wayne67vert is offline   Reply With Quote
Unread 09-04-2010, 03:25 PM   #3
Davestone
Florida Tile & Stone Man
Was he a lawyer or engineer?
http://Davestonestile.com
Unread 09-04-2010, 03:26 PM   #4
Wayne67vert
Tile Contractor
Dave, you have worked for both also?
Wayne
Unread 09-04-2010, 03:42 PM   #5
ob1kanobee
ob1kanobee's Avatar
A buddy of mine installs Dish TV. He put a dish on a new customers house the other day and the owner got all pissed off. I'm not sure how the guy thought he was going to pick up signal but this guy got irate with my friend. Bunch of wackos out there.
With that said though, we always used the same kind of screw but just longer on the outlets. Carried them in a special container in the van.
Ben
Unread 09-04-2010, 03:55 PM   #6
Davestone
Yes
Unread 09-04-2010, 05:33 PM   #7
gueuzeman
6/32 1 1/4" machine screws. I buy 'em by the 100 box, will last about a year depending on how many outlet's you're tiling around.
Costs about $5 for the box.
If you are using drywall screws you're a hack. Sorry.
Think about if you took your car to get new tires and the "mechanic" used improper lug nuts and just mashed them in all cross threaded with the impact gum, ruining the lugs.
gueuzeman is offline   Reply With Quote
Unread 09-04-2010, 05:43 PM   #8
tilejoe
tilejoe's Avatar
I used a drywall screw once, the home owners father came by (an electrician) and reemed me out for it. that was back about 10 years in my beginning, but i never forgot it.
We all know it will work just fine, forever, but....
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 09-04-2010, 05:59 PM   #9
gueuzeman
Scott- look, I'm not trying to be a d***, but..... ok, I'm a d***.
By the same token I could tile a shower with mastic on hardibacker......
Joe- the funny thing about that story is that usually it's me reaming out the electricians for using the drywall screws.
Unread 09-04-2010, 06:12 PM   #10
Jhereg
Signature Tile - Owner
Jhereg's Avatar
This is one area I think I have to step it up. I've often (on jobs I'm working directly with the homeowner) just told them they need to pick up new longer screws. If I'm subbed, I let 'em hang for the electrician's return.
Think I should go pick up a box of longer screws and be a problem solver instead.
Chad N. owner
Signature Tile - Renton, Washington
www.signaturetile.net (a work in progress)
Jhereg is offline   Reply With Quote
Unread 09-04-2010, 06:25 PM   #11
gueuzeman
Unread 09-04-2010, 06:37 PM   #12
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
Dang I do the same thing, I have always just left em hanging for the sparky. Guess I should go buy a box too
Levi The Tile Guy
Unread 09-04-2010, 06:44 PM   #13
HS345
Tile Contractor
HS345's Avatar
I use the machined screws also, except for the occasional rare stripped out hole. If it's my own job I screw alla devices back in, if it's not, I don't, unless it's just a couple.
I have also seen electricians use drywall screws.
The name's Greg
Unread 09-04-2010, 07:13 PM   #14
scott anthony
OK then I am in the wrong here and have been for nearly 15 years without a single problem. I do respect the info of those who do use the machined screws, but I have looked for them and never found box's or bags more than 10 at a time, maybe I will just research harder. I can change my ways and do often depending what direction needs to be taken.
I have been using the fine thread 1 1/4's.
Now as for hack comment using a fine thread screw which is similar to the machined is nothing like mastic in a shower, thats not even in the same ball park, dam Gueuz ya had a bad man?
Scott
Unread 09-04-2010, 07:29 PM   #15
Shawn Prentice
Scott, I've bought mine at an electrical supply store before.
Shawn Prentice is offline   Reply With Quote
Back splash Advice BingoSteve Tile Forum/Advice Board 21 11-28-2009 12:57 PM
grouting back splash Peter Tile Forum/Advice Board 11 08-05-2008 11:13 AM
Tile under switch plates/outlets help please coffeecup44 Tile Forum/Advice Board 11 01-14-2008 06:29 AM
Kitchen Back splash Jason0475 Tile Forum/Advice Board 7 06-17-2006 05:03 AM
Back Splash Electrical Outlets giarc25 Tile Forum/Advice Board 13 08-21-2005 07:55 PM
