Unread 09-06-2017, 11:43 AM   #1
JamesH
Variation in Grout Joint Width
Hi,
I'm new to the site and need some advise.
I just purchased a new home and in the shower, at eye level, there is one vertical grout joint that is over 2 time the size of the immediate surrounding grout joints. The tile installer said it was up to industry standard and will not fix it. The developer agrees with their subcontractor.
The Tile Council of North America unfortunately does not address this but only address the variation in tile size which will cause variation in grout width.
I feel my problem is basically poor workmanship. The tile installer probably cut the tile too small and installed it anyways.
Is there any written specification that I can use to make them correct this.
Thank you in advance for your help
James
James
JamesH is offline   Reply With Quote
Unread 09-06-2017, 02:07 PM   #2
James you are correct about the variation in tile size having an impact on the grout joint size.
The question becomes, will the repair cause more damage than good?
Unread 09-06-2017, 03:52 PM   #3
Hi James,
Back up a little and give us more joints to look at.
Unread 09-06-2017, 09:28 PM   #4
PetrH
this grout line variation is sometimes necessary and sometimes just poor workmanship. In my personal oppinion it's not great, but not terrible either. Looks like you're stuck with it, so stop obsessing about it and enjoy your new home.
Petr
Unread 09-06-2017, 10:22 PM   #5
While it's nice to have all the grout joints the same size, the one shown in your picture isn't that bad, and if that's the worst of it, I wouldn't obsess over it.
Unread 09-07-2017, 03:43 AM   #6
evan1968
Not So Senior Contributor
evan1968's Avatar
If the tile came from HD or Lowe's, those are grout joints you are going to have to live with.
We have seen much worse.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 09-07-2017, 10:59 AM   #7
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
James. We are the first ones to say that someone else's work sucks. But we will need a picture of the whole area to make that call.
You say that you think they cut the tile too small. I don't see anything that says it's a cut tile. But then again, i don't examine pictures that well.
There is a good chance that the tile is up to snuff. But i feel you. Nothing worse than a crappy grout joint at eye level. Especially in a brand new house that you are paying for.
Is this s tract house? I would call that tile good if so. Especially if it's the only issue. Probably not worth tearing a whole in a shower to fix it.
Is this a million dollar custom home? Then they better get back there and fix it.
We need a pic from further back.
I am neither clever nor funny
Travis
It's just a clever handle.
Last edited by Shady at Best; 09-07-2017 at 11:11 AM. Reason: Read the original post for once.
grout shade variation Charles Settle Tile Forum/Advice Board 5 10-26-2011 10:59 AM
Joint Width for Subway Tile Backsplash reins Tile Forum/Advice Board 2 01-29-2006 04:11 PM
floor tile joint width simonmeridew Tile Forum/Advice Board 1 11-17-2001 07:49 AM
Grout color variation zel Tile Forum/Advice Board 17 11-05-2001 08:38 AM
Moving grout joint width discussion LDavis Professionals' Hangout 4 07-25-2001 07:22 PM
