Unread 09-05-2017, 10:39 PM   #1
prancer
Ledge stone installation questions
Have a few questions on a ledgestone install. I've searched the forum for answers , but have come up with more questions instead of getting answers.
The pictures below are the product and the area I want to install. The wall is 90" high 12' wide and the fireplace face wall is 90" x 102" wide. My walls are 5/8" Sheetrock that has been glued and screwed when installed. The primer on the wall is kilz and has been painted for about a year now.
1- Can i install directly to the drywall if I rough it up with 60 grit paper?
2- do I follow the floor when I place my first row or should I make it level. The floor is about 3/8" lower on one end.
3- do mitered corners look better than the chiseled pre-made corners.
Mark
prancer is offline   Reply With Quote
Unread 09-06-2017, 01:03 AM   #2
PetrH
I'm sure the mods will move this to the regular forum for you.
1: yes, you can install directly on drywall with a decent modified thinset, I'd go with white to make install easier.
2: Yes, make your first row level. Also measure how things will work out top and bottom of fire place and at the ceiling. Adjust your bottom row to make everything work out nice.
3: pre fab corners look better and will also save you a tonne of time, but mitered corners are possible. When mitered corners are desired, I charge an extra 4 hours on a job like this to cut them. I'd say it will take you even longer than that to do.
Petr
Stonecraft Luarel Cavern Ledge Installation Help Needed Jsimoske Tile Forum/Advice Board 1 09-12-2014 03:01 PM
Desert quartz ledge stone in shower? jroush Tile Forum/Advice Board 2 04-19-2013 12:18 PM
Stone Tile Floor Installation Questions mrused2b Tile Forum/Advice Board 15 02-01-2012 10:07 AM
Granite ledge questions Madam Tile Forum/Advice Board 5 01-18-2010 05:46 PM
stone on covered concrete porch, many questions about installation! Theresa Tile Forum/Advice Board 14 11-02-2006 10:38 AM
