Unread 08-03-2017, 06:11 PM   #1
Premier Designs
Diagonal Flemish Bond
Any of you guys done one? Doing a shower for a client, proposal was for a straight Flemish bond, the day I started she changed her mind ... odd, I know, lol .. anyway, what's a reasonable up-charge for diagonal?
I've got double the time in it so far and only 3/4's done sticking the walls ..
I appreciate any input.
www.premierdesigns4u.com
Premier Designs is offline   Reply With Quote
Unread 08-04-2017, 03:31 PM   #2
Premier Designs
Unread 08-04-2017, 04:47 PM   #3
Premier Designs
Maybe someone can turn the image ... ?
Unread 08-04-2017, 08:11 PM   #4
eurob
Not...Sure
Turning the image
Size:  39.7 KBPremier design work
Interesting pattern ....I think this type of installation -- brick work -- is used for structural walls , where one or two walls are tied behind it .
Roberto
Unread 08-04-2017, 09:21 PM   #5
Premier Designs
You're correct, I wrapped the pattern around all 4 walls, it's pretty difficult to see it in the small space of this shower, I did a scale mockup before starting it to show her, but she wanted it anyway.
It'd look much better on a larger surface where you could actually see the pattern ..
And thanks for fixing the image ..
Unread 08-04-2017, 09:31 PM   #6
Premier Designs
Here's a better look .. this is the picture I'm using for reference.
Unread 08-05-2017, 12:15 AM   #7
eurob
Not...Sure
Now we can see what the pattern looks like
Couldn't figure it out why 3 rows follow the patern , then 3 are different .
Roberto
Unread 09-01-2017, 05:55 PM   #8
Premier Designs
Ok girls, here it is. Comments?
Unread 09-01-2017, 05:56 PM   #9
Premier Designs
Sorry about the sideways pics, I need help from eurob again ... lol
Unread 09-01-2017, 06:09 PM   #10
Premier Designs
I had 60 hours in just the walls, if I ever duplicate this, It'll be about double of what I charged her. 4 gallons of acrylic grout in there ..
I ended up hand laying each pebble, that was fun.
Unread 09-01-2017, 06:11 PM   #11
Premier Designs
And no, the mosaics didn't come like that either, all hand done, cut and paste ...
Unread 09-02-2017, 12:54 AM   #12
PetrH
I always lay all my pebbles individually. IMO it's the only way to keep the sheets from ghosting through. It's a really sharp looking shower, I just don't see why this would have taken any longer than the usual 1/3 offset. I mean the number of cuts is the same, so why would you charge more?
Petr
Unread 09-02-2017, 07:02 AM   #13
tilemanct
Tile & Stone
Anytime you go outside the norm you should charge more!!! Nice job.
CTEF Certified Installer
Unread 09-02-2017, 11:47 AM   #14
eurob
Not...Sure
Like the ceiling a lot -- pattern -- , but missing one black dot .
Could've do some pattern with the shower floor -- looks like part flower like around the drain -- , similar as concept as the ceiling.
The tiled flemish bond needs a wider joint to look like it
More comments needed ....lol
Roberto
Unread 09-02-2017, 11:57 AM   #15
eurob
Not...Sure
Not my work....
Name:  Flemish bond 1.jpg
Name:  Flemish bond 2.jpg
Size:  39.8 KB Nice detailed installation, Dan.
Roberto
To Bond or Not to Bond (pre-slope) tearendt Tile Forum/Advice Board 2 07-09-2013 02:28 PM
Bond Fat mud????? TGR Professionals' Hangout 18 10-09-2007 08:44 AM
running bond on diagonal kevjob Professionals' Hangout 10 03-02-2006 07:02 AM
Top'N'Bond dnlblank Tile Forum/Advice Board 5 05-03-2005 09:39 AM
To bond or not to bond PVC Drain gchamilton Tile Forum/Advice Board 4 07-20-2004 04:52 PM
