Unread 05-10-2012, 04:08 PM   #3106
Steve in PA
Tile Contractor/ Installer
Steve in PA's Avatar
If this was a contest... I might just have the winner...
Steve
Steve in PA is offline   Reply With Quote
Unread 05-10-2012, 04:53 PM   #3107
Steve in PA
This was just built about a month ago... nice basket weave stone mosaic floor.
Curb-less shower with no waterproofing... no pitch... CB screwed to plywood, no thin-set. Heat-mat ran into shower area... the lead went up the inside shower wall to a thermostat in the bedroom. There was more pitch in the main floor area outside of the shower... water pooled where you see the white towel. The whole room was out of square, level. Old house but the hack/builder had an empty down to studs and open floor joist... no excuse.
Steve
Unread 05-10-2012, 08:43 PM   #3108
gueuzeman
I hope it was at least a second floor shower that leaked into the first and ruined a ceiling! Wood looks to be in good shape. Failed too fast for any rot to occur? How old/how many uses before problems occured?
gueuzeman is offline   Reply With Quote
Unread 05-11-2012, 01:52 AM   #3109
Hank B.
I'm thinking once they noticed the water running out of the shower and pooling up in the middle of the bathroom, they new something was wrong.
Hank
Hank B. is offline   Reply With Quote
Unread 05-11-2012, 06:56 AM   #3110
Steve in PA
You are correct Gueuze... in that ripping it out so soon after install, there was no major water problems. The wood in the curb was wet and there is a decent size area where the plywood's top layer is dark and damp. It is second floor but the few uses had not caused a problem in the ceiling... yet. It was just a matter of time.
The black dots highlighted the "out of square"... nothing was flat especially where they set over the heat-mat. That mosaic pattern has a basket-weave look... this install had the texture of a basket.... many of the small black accent dots were 1/2 to fully covered with grout.
Hank is also correct in that the pool outside the shower forced the issue on the need for correction.
Steve
Unread 05-13-2012, 11:22 PM   #3111
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I got a call from one of the owners of the local tile stores if I could inspect a job that he sold the tile for. The tilesetter installed 12" x 24" porcelain on 50% offset with 1/16" grout joints. I expected some lippage due to natural warpage in the tile. Then he texted me this picture.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 05-13-2012, 11:52 PM   #3112
Katwyk tile
Isaac, Some of the people I work for pay extra for that look.
Katwyk tile is offline   Reply With Quote
Unread 05-14-2012, 12:49 AM   #3113
Charimon
I think i have seen that exact tile - with the same cuping in a shower I was asked to look at. In my case the tile was purchased by the owner and set by her tile guy who showed her 2 pcs face to face before he started. I will look up the brand and name to see if it is.
craig
Charimon is offline   Reply With Quote
Unread 05-14-2012, 05:26 AM   #3114
Hammy
Hammy's Avatar
Send a message via AIM to Hammy
If the first joint doesnt trip you the next one will.
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Professionally Built Mold - Mildew - Moisture Resistant Showers
Using Laticrete & Schluter Products
Click here to Visit us on Face Book
Hammy is offline   Reply With Quote
Unread 05-14-2012, 05:08 PM   #3115
wow, that's even worse then the Florida hacks !
Unread 05-14-2012, 05:15 PM   #3116
evan1968
Not So Senior Contributor
evan1968's Avatar
The floor looks like it was woven.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 05-14-2012, 06:07 PM   #3117
gueuzeman
Considering how badly warped the tile appears to be, I would say that the installer did a pretty good job.
What I'd like to know is who's idea it was to go with the 50% offset and the tight joint, the salesperson or the homeowner.
I'm not saying that the installer is up to date about the "newer" TCNA spec "side longer than 15 inches....." thing, but design is usually dictated by others than the installer. For all we know the installer didn't want to do it and was browbeaten into doing it from those wielding a checkbook as a cudgel.
Unread 05-14-2012, 07:46 PM   #3118
Unread 05-14-2012, 07:53 PM   #3119
Steve C
Steve C's Avatar
That's a super-nice cut-in for the light fixture. Square, round, it's all the same, eh?
Steve
Steve C is offline   Reply With Quote
Unread 05-15-2012, 05:32 AM   #3120
Gary K
Vendor
Gary K's Avatar
Brian, you find all the great pics. A little bit of caulk will fix that fixture, nobody will ever notice it.... WINK WINK...
Picking them up and putting them down.
Gary
Gary K is offline   Reply With Quote
Absolute worst tile finishing job pitterpat Professionals' Hangout 17 04-02-2007 07:12 PM
worst of the worst... botched jobs Dan O'Connor Tile Forum/Advice Board 5 02-22-2007 03:21 PM
best and worst tile saw in $300-$500 range LinLee Tile Forum/Advice Board 9 01-30-2006 01:50 AM
best and worst tile saw in $300-$500 range johnnyaico Tile Forum/Advice Board 10 01-27-2006 03:05 PM
The worst job................ opiethetileman The Mud Box 6 10-08-2004 10:48 PM
