Unread 03-24-2012, 08:26 AM   #196
here's a niche from a master bathroom shower renovation in Apollo Beach, Florida.
customer wanted the glass & marble mix accent band on walls.
I suggested to run it through the center line of niche and then tile the back of the niche.
Unread 04-08-2012, 07:48 PM   #197
Steve in PA
Tile Contractor/ Installer
Steve in PA's Avatar
here is one I just did... they recessed the shower controls because their glass door is designed to swing into the shower and they didn't want it to hit the valves. they also wanted a shaver shelf for the wife so this is what I designed.
Steve
Steve in PA is offline   Reply With Quote
Unread 04-08-2012, 08:14 PM   #198
Dave Taylor
Retired Moderator - Veteran DIYer -- Schluterville Graduate
Dave Taylor's Avatar
Nice work Steve.
Dave T (DIY'er)
Welcome to "Tile Your World", the friendliest forum on
the net.
Dave Taylor is offline   Reply With Quote
Unread 04-08-2012, 08:58 PM   #199
tiletime56
Shaun Haley Tile
tiletime56's Avatar
Send a message via Skype™ to tiletime56
room for your towels lol
Shaun
https://www.facebook.com/lists/22363...e/172655561618
Luv fat mud!
tiletime56 is offline   Reply With Quote
Unread 04-09-2012, 07:37 AM   #200
That must have been hell laying out the diagonals with that pattern.
Inward swinging shower doors have been contrary to code every place I've worked. They swing out so you can exit in a hurry if you have to -- scalding water, etc.
Unread 04-09-2012, 07:44 AM   #201
John R
I was told here that outward swinging doors had to do with allowing access by emergency personnel if one falls/is down in a shower.
John R.
San Jose, CA
John R is offline   Reply With Quote
Unread 04-09-2012, 11:08 AM   #202
That, too.
Unread 04-10-2012, 06:20 AM   #203
Steve in PA
Thanks Dave... and yes John it was a PITA turning that 45 around the corner and recess. I'll mention the emergency access logic to the homeowners... the man is diabetic and does have issues with his feet and sight. Thanks for mentioning that John R. I would think they can get a hinge that swings both ways. PA has a minimal amount of "code" enforcement. Although many should have a permit for elec/plumbing... 99.9% of remodel work is done w/o a permit. Even on jobs that have a permit, new construction/additions, nothing I do tile wise requires an inspection/sign off.
Steve
Unread 04-10-2012, 09:30 AM   #204
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
Here is one I just did, nothing special but I used Kerdi board and cut in my niche after I pulled layout, and it worked out perfectly.
Levi The Tile Guy
Grand Junction, Colorado Tile and Stone installation
Levi the Tile Guy is offline   Reply With Quote
Unread 04-10-2012, 10:37 AM   #205
Gary K
Vendor
Gary K's Avatar
Looks good Levi. What mud did you set the tile with?
Picking them up and putting them down.
Gary
Gary K is offline   Reply With Quote
Unread 04-10-2012, 12:55 PM   #206
Levi the Tile Guy
I actually used LFT on that one. I am not worried for one minute about the mud not curing under the slate. I normally use Kerabond though.
Levi The Tile Guy
Unread 04-10-2012, 01:09 PM   #207
Gary K
Vendor
Gary K's Avatar
Thanks Levi. I normally use 3n1 by Tec. I have been wanting to use the Kerdi board, but I won't be able to use the 3n1 with it, due to it being a modified thinset.
Gary
Unread 04-22-2012, 07:13 PM   #208
ssailer
ssailer's Avatar
Here's a contemporary one that I thought turned out pretty cool. I edged the tub surround with the same Schluter.
Scott
ssailer is offline   Reply With Quote
Unread 04-22-2012, 09:33 PM   #209
silvercitytile
silvercitytile's Avatar
Send a message via MSN to silvercitytile
Nicely done Scott!
jeff aka papi chulo. "I'll make you famous!"(William H. Bonney aka Billy The Kid)
Schluter Kerdi and Ditra installer in Southern New Mexico
Castillo Construction
silvercitytile is offline   Reply With Quote
Unread 04-22-2012, 09:58 PM   #210
jwmezzanotte
jwmezzanotte's Avatar
From last week..
I go a little crazy with the green tape Gets those schluter pieces just where I want them though
jwmezzanotte is offline   Reply With Quote
Need some pictures lasvegaslenny Professionals' Hangout 18 07-01-2010 07:08 AM
pictures nj jake Professionals' Hangout 7 03-06-2009 10:06 AM
pictures please clarke Tile Forum/Advice Board 1 04-12-2005 09:32 PM
At last - pictures CMHCissell Tile Forum/Advice Board 8 02-06-2004 08:01 PM
pictures? Bri Tile Forum/Advice Board 6 05-08-2001 04:14 PM
