Unread 05-27-2010, 12:37 PM   #1
Kevin M
Porcelain tiles with a "sheen"
Hello everyone,
We recently put down a porcelain tile floor (Rialto beige series from Lowe's). After grouting it and removing the excess and the haze, the tiles now have a "sheen" to them around the grout lines. The middle of the tiles do not, they are the original matte finish.
We have tried mixing vinegar and water and getting a haze remover with no luck. We are really worried we will not be able to remove it and the job won't look as good as it could. Any help is appreciated. It's been about a week and a half, hoping it's not too late to get this stuff up.
Thanks.
Kevin M is offline   Reply With Quote
Unread 05-27-2010, 03:11 PM   #2
well the Rialto is a good porcelain tile and I doubt you cant stain it.
what type of grout did you use and what type of water do you have at your home ?
Unread 05-27-2010, 03:47 PM   #3
Davestone
Florida Tile & Stone Man
If it wasn't sealer the only thing i can think of is maybe it's moistureand will dissipate in awhile.
http://Davestonestile.com
Unread 05-28-2010, 08:50 AM   #4
Kevin M
Grout was the premixed stuff from Home Depot, the color is "Haystack". (I'd put a link, but the forum won't allow me - the SKU at HD is #785173 (different color).)
As far as the water goes, we live in St. Louis, I hear it is somewhat "hard". We used tap water with no filtration.
I used straight vinegar again last night with a scraper and then the haze remover again with no change. When I look at it closely, it looks like there are streaks or swirls. Does that mean anything?
@Dave - we didn't seal it, although the grout says it is stain resistant.
Unread 05-28-2010, 03:06 PM   #5
SyTile
In the premixed grouts, another cleaning is commonly required after completion. In looking at the data sheet for the product you're using, http://www.jamoinc.com/documents/ds_...x-grout-ds.pdf, it is recommended to use TileLab Grout & Tile Cleaner to remove the excess haze. I would use a white scrub pad to assist in removing the haze left around the edges.
Travis Johnson
Syverson Tile & Stone
SyTile is offline   Reply With Quote
Unread 05-28-2010, 08:46 PM   #6
Kevin M
Success! I bought some scrubbing pads today and the sheen/haze is coming off with straight vinegar that sits for 1-2 minutes. It's going to take some work, but it looks like our tile job won't be ruined after all. Thanks everyone for the comments.
Reduce 12" X 12" ceramic tiles to 9.5" X 9.5" cogman79 Tile Forum/Advice Board 4 01-03-2009 04:23 PM
Meridiana Porcelain 13" x 13" floor tiles Frances Tile Forum/Advice Board 3 02-16-2008 11:24 AM
Problems with 20" x 20" porcelain tiles? LadyGodiva Tile Forum/Advice Board 3 10-23-2007 10:03 AM
13" Porcelain Tiles brians Tile Forum/Advice Board 5 04-03-2006 11:06 AM
20"x20"(500mmx500mm) Porcelain Tiles (Polished) David Webster Tile Forum/Advice Board 13 05-24-2004 04:49 PM
