Unread 10-29-2008, 06:04 PM   #1
001
Ted - Registered Lurker
Oatey with Kerdi Question
I apologize for having to bring up the subject, which I realize has been addressed before . . . but I would appreciate a bit more clarification on the issue.
And before I ask, since this is my first post, I wish to send a BIG thank you to Mr. Bridge for both the fabulous Kerdi Shower book . . . and of course, this forum, the best resource for tiling in the world.
I'm starting on a shower project that was partially finished by someone else. There is a new Oatey drain and preslope already installed.
I would like to use Kerdi. Replacing the Oatey drain with the Kerdi drain is problematic (I'm told there is hydronic radiant floor heating in the concrete that I might damage if I chisel out the Oatey drain).
I've read that the Kerdi don't mix with the Oatey drain, but I'm sittin' here looking at this thing and I can't see why not.
If I set the Kerdi in a bed of caulk on the drain I'm athinkin' it's going to be as water-tight as a frog's ass. The drain happens to be set low enough that if I screw down the other components all the way there is just enough room for my thinset and tile.
What am I missing?
001 is offline   Reply With Quote
Unread 10-29-2008, 06:17 PM   #2
phobbs
There is a adaptor available now I believe. Check with your local TM
Peter
"It was a woman that drove me too drink, and I haven't found her to thank her yet" W.C Fields.
phobbs is offline   Reply With Quote
Unread 10-29-2008, 06:19 PM   #3
Davestone
Florida Tile & Stone Man
I can't see why not either, and if i did it,not sayin it's right mind you, i'd start out with a 1 foot square of Kerdi around the drain,to double it up,and silicone under the bottom piece and the flange.
http://Davestonestile.com
Unread 10-29-2008, 06:34 PM   #4
ddmoit
ddmoit's Avatar
Welcome to the forum, 001. What name can we call you by?
Hopefully you can do better than that. It turns out that frogs absorb water through their skin instead of drinking it.
Dan - a DIYer in SE Tennessee
Unread 10-29-2008, 06:43 PM   #5
Davestone
I wish i could do that,save me a lot of time in the Florida summers.
Unread 10-29-2008, 07:08 PM   #6
try looking at the Noble Flex - Drain Flashing.
Unread 10-29-2008, 08:16 PM   #7
001
Thank You
Thank you gentlemen. Brian, the NobleFlex that you recommended looks perfect! A wonderful solution!
Cheers!
Unread 10-29-2008, 08:35 PM   #8
Schluter makes a hat, but I don't think they warrant it since they have a killer drain.
http://www.indianafloorsllc.com/prod...x?pid=10778446
Kerdi Hat
Add To Cart
Product Detail
Unit Of Measure:
Price: $9.00
