Unread 02-07-2013, 08:50 AM   #1
tp13dan13
Red face CBU to Drywall Transition & Squareness
Hello All,
I have just installed the CBU (hardibacker) in my shower/bath. I furred out the studs beforehand so the CBU will overlap the tub tiling flange (I plan on using Redgard, hence the overlap). I noticed there are still some area in which the CBU is not completely square, especially where the CBU meets existing drywall in which the drywall comes out from about 1/8" more than the CBU (I am using 1/2 thick CBU).
Questions:
1. What is the best way to fix this transition?
2. How perfectly square does the CBU need to be in order to tile properly? If I move my level around on the CBU I can see some variation throughout the shower but nothing too dramatic...is this normal or should I make sure the CBU is perfectly square around the tub?
3. (unrelated to this post title but still the same project)...I will be using 8x12 tiles and planned on staggering rows. I purchased bullnose for the edges but am wondering how you would use bullnose if every other row is staggered a half tile from the one above and below it. If this doesn't make sense I can draw a picture to describe it. Would you end up with a half tile that transitions into a small bullnose piece? Thought that may look wierd..
I appreciate the help!
Tom
Tom
tp13dan13 is offline   Reply With Quote
Unread 02-07-2013, 09:07 AM   #2
Tom,
1- If this is outside the wet area, tape and float like drywall. If inside the wet area, tape and float with thinset
2- How much out are we talking? with that sized tiles slight humps will not matter as you can use a slightly larger trowel
3- check out the subway tiling tutorial and look at the pictures for inspiration and ideas. Then do what Mrs Tom wants.
Shower Surround CBU/Drywall Transition Tradesman2010 Tile Forum/Advice Board 46 02-03-2011 06:48 AM
CBU/Drywall joint & shield ne253 Tile Forum/Advice Board 1 02-26-2009 01:55 PM
CBU to drywall transition question Yaknvdub Tile Forum/Advice Board 9 10-05-2007 06:40 AM
Adhesvie for tile on transition from CBU to Drywall Tim39 Tile Forum/Advice Board 5 03-05-2006 08:50 PM
Transition From Cbu To Drywall MChartre Tile Forum/Advice Board 6 07-04-2005 07:11 PM
