Unread 07-19-2022, 04:01 PM   #1
zimm0who0net
Ditra over plywood with impervious foam on back
About to Ditra an entire 2nd floor. One room goes over an outside area. The 1-1/8" plywood subfloor has a 2" closed cell foam sprayed underneath it as insulation. I know the rule is modified under ditra and unmodified over ditra, but I'm wondering if this might be an exception. I'm not sure the latex in the modified thinset will cure properly given that the moisture can't escape up (through the ditra) or down (because it'll hit the foam after going through the plywood).
Thoughts?
Also, is there a lot of difference in unmodified thinsets? I thought they were basically just portland and sand. So why does Mapei alone have six different products in that category?
Rich
zimm0who0net is offline   Reply With Quote
Unread 07-19-2022, 04:29 PM   #2
FWIW, today, not that many modified thinsets still use latex. Because the plywood still moves with seasonal changes, you would want to use the specified modified thinset. The ply will absorb some of the excess moisture, so I don't see a problem, but you could call Schluter and ask their tech support for confirmation. The moisture issue occurs when you have two impervious surfaces sandwiching the modified thinset...you don't have that...the ply will deal with any excess moisture.
Unread 07-19-2022, 04:44 PM   #3
zimm0who0net
Ok, so you're saying that even though the ply and the mortar are between two impervious surfaces (the foam and the ditra), the plywood will act as a "sponge" (for lack of a better term) and let the thinset dry properly.
That makes sense...
Rich
Unread 08-01-2022, 07:58 AM   #4
pdeluca
In response to your question "So why does Mapei alone have six different products in that category?" MAPEI is a tile mortar manufacturer so we continue to add new products as the industry changes and evolves. MAPEI makes some tile mortars only sold at Lowes, some are thinset mortars for smaller tiles, and others are for large format tiles with non-sag non-slump properties.
Patty
pdeluca is offline   Reply With Quote
Heated Garage floor with 3" pink foam board, What is easiest subfloor plywood +hardi? rollandelliott Tile Forum/Advice Board 29 06-27-2014 06:38 AM
Plywood subfloor, foam, and that 1/8" Gap metal121 Tile Forum/Advice Board 3 10-30-2008 05:59 AM
underlay requirements over insulated concrete? (plywood/OSB/foam board) dougabowski Tile Forum/Advice Board 3 04-12-2007 05:00 PM
Ditra- exterior on impervious surface Jeffrey (dsnbld) Tile Forum/Advice Board 29 01-12-2007 10:01 PM
