Unread 06-10-2019, 07:41 PM   #1
Elkski
Elkski's Avatar
Cutting outlet holes?? How u do?
Just wondering what tricks you guys use to cut outlet holes. I cut outline and an X from both sides then angle grinder.
Teddy
Unread 06-10-2019, 08:30 PM   #2
CaliGrown
CaliGrown's Avatar
How you did it for most cases. Some tiles are fragile and I’ll drill out the corners then cut-out with the grinder. Best thing is to mark out your cut on both sides, cut the front without overcutting then just overcut on the backside. Then knockout corners or tile teeth if you need to, nippers help with that.
Christopher Machado
1 (916) 990-1751
Unread 06-10-2019, 09:00 PM   #3
Same as you, but without the crescent wrench.
Do you mind if I move this thread to the Pro Hangout?
Unread 06-11-2019, 06:06 AM   #4
Elkski
Elkski's Avatar
sure move it to where this should be... I knock it out with the closest hard tool.
Teddy
Unread 06-11-2019, 06:16 AM   #5
Gozo
Just as Chris does. I use a 1/4” core bit for the corners. It doesn’t leave a perfect square cornered hole, but for outlets and such I’ve never needed that level of perfection. I pretty much go right through so nothing to knock out. Use the nippers on any remaining edge pieces.
I found, for me at least, if I work at a higher level it’s easier on my back. I used a plastic full sized garbage can upside down with a piece of carpet remnant for cushioning and support underneath. This forces it to be outdoors because it kicks up a ton of dust. Mask and face shield are a necessity.
Jeff
Unread 06-11-2019, 11:12 AM   #6
TileStuff
Coring bit and a diamond jigsaw blade works well. No smashing needed, if you have some delicate material.
Jesse
TileStuff is offline   Reply With Quote
Unread 06-11-2019, 12:38 PM   #7
Elkski
Elkski's Avatar
It was a love tap and all 4 dropped out.
Teddy
Unread 06-11-2019, 03:58 PM   #8
In my case that would be a head-butt.
Cutting subway tile around outlet joevc1 Tile Forum/Advice Board 2 07-13-2015 07:56 AM
Cutting tiles for outlet??????? DIYourselfer Tile Forum/Advice Board 6 12-09-2008 07:18 PM
Cutting Ceramic Tile for Electrical Outlet jkittle Tile Forum/Advice Board 31 10-05-2008 10:28 AM
Cutting mirror for outlet box gary329 Tile Forum/Advice Board 4 04-07-2008 04:51 PM
cutting outlet holes in granite Katebrown33 Tile Forum/Advice Board 5 03-15-2007 01:25 PM
