Unread 05-22-2006, 10:28 PM   #1
ruben7566
Unhappy Whats the best Thinset to use for wall tile
Can someone recommend the best thinset for wall bathroom porcelain and ceramic tile made in Spain?
Can you add the Arcylic Glue to the thinset mortar and make it stronger?
thanks
Ruben
ruben7566 is offline   Reply With Quote
Unread 05-22-2006, 10:44 PM   #2
Mike2
I don't know what the best one is Ruben but Custom's VersaBond is plenty good enough. No additional glue necessary, guaranteed.
Unread 05-24-2006, 08:09 PM   #3
MudMaker
MudMaker's Avatar
Ruben, Are we talkin wet area or dry area? Cause if it's it dry, you can use mastic.....
Sorry Ruben, I see you have another thread where you are using it in a wet area.. If you keep all of your install on one thread, it will be easier for the guys n gals to help.. That way they can see what you got goin on....
mm (aka "Paco")
Unread 05-24-2006, 08:18 PM   #4
Trask
Oregon Tile Man
Trask's Avatar
Customs Versabond or flexbond(more than you need),both are cost effective easy to use(read the directions on the bag) and will last as long as you want.
Good luck and Have Fun
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
