Old 11-18-2018, 09:26 AM   #1
Icicleboy
Curbless shower with Nuheat?
Hey all! Long time reader/lurker and newly a member of the forum. I've successfully built a shower using a combination of mud pan, hydroban, wedi boards before but am now starting a new project that requires some input from the experts
I'm looking to build a curbless 3 x 5 shower. I'm not set on a drain style yet (linear or square offset are both fine) and am looking to extend Nuheat membrane and heat over to the floor of the curbless shower. I have been looking at Wedi pans that are preformed. Assuming the wedi pan transitions to the plywood subfloor seamlessly (flush) can I just take the Nuheat membrane right over the pan? Because of the different slopes in different directions towards the drain I wasn't sure if the membrane could accommodate that or not? Any other advice where this is concerned? If it's too much of an obstacle I'll just keep the heat out of the shower pan.
Thanks so much in advance.
Icicleboy is offline   Reply With Quote
Old 11-18-2018, 10:04 AM   #2
rmckee84
rmckee84's Avatar
I'm sure its possible but it would be worth giving wedi a call and asking their thoughts.
Ryan McKee
Old 11-19-2018, 11:20 AM   #3
Hi Kevin,
Some heat mat manufacturers make systems for wet areas. I would look for one of those. Otherwise, I don't see any problem with the installation.
Old 11-19-2018, 09:32 PM   #4
Many of the heating systems require them to be beneath a waterproof surface when used in a shower. Since Wedi is the waterproofing, that could be a problem when trying to use one on top of it. You need to read their installation instructions carefully, and personally, I'd call them to get their thoughts, along with Wedi.
curbless shower help Bird gang Tile Forum/Advice Board 3 10-09-2016 12:20 PM
Shower renovation with Kerdi and NuHeat taj7334 Tile Forum/Advice Board 78 12-01-2013 09:44 PM
curbless shower (or almost curbless) Apt4C Tile Forum/Advice Board 656 03-08-2011 09:58 PM
Nuheat in shower problems ben-e Tile Forum/Advice Board 6 01-23-2009 10:51 AM
Nuheat cable electric heat inside shower pan?? claycarson Professionals' Hangout 7 05-05-2008 05:55 AM
