Unread 08-10-2017, 05:12 PM   #1
GUGLHUPF
Glossy Paint on Wall
Hi,
Background:
I would like to make my bathroom a little nicer. When we got the house the bathroom was simple painted with a very shiny paint. It could be enamel paint, though I don't know enough about paint to be sure. I would like to put tile up on one wall to break up a very large and very boring wall. About 9 feet long and chest high.
I think the mortar would not stick to the paint. There is a little bordure round the bottom with some carrara ceramic tile, just like the floor. Between the painted wall and the front of the bordure I have about 12mm.
Plan:
I think to deal with the shiny paint, the easiest for me would be to get 1/4inch cement board and screw it over the existing drywall ( with the shiny paint ). Then use some 1/4 inch tile. This should be roughly flush with what is there already.
Questions:
Is this a good plan? If it is and since this is a bathroom do I need to do some special sealing/waterproofing/foil/taping, that stuff? If I do, is this described somewhere how to do it? I will only add to the wall so I am not sure if anything is needed. However I am thinking humidity may enter and be trapped between the current wall and the soon to be installed cement board. Which is why I am asking.
I think the alternative is to use chemicals and sanding to roughen up the existing wall. I think this would be way messier and more work overall. I don't feel quite confident in it.
About me:
As a background I did never tile anything. I am a reasonably good handyman. The closest work so far has been that I put a floating bamboo floor in my sunroom, which was easy. I want to tackle this project to learn tiling and to make the bathroom look a little less boring. There is a good chance that we'll have professional remodelers do the bathroom in 2 years. So this may be throw away work and doesn't have to look perfectly. I do not want to live in a house with mold though.
Ralf
GUGLHUPF is offline   Reply With Quote
Unread 08-11-2017, 09:16 AM   #2
Welcome aboard, Ralf.
If you don't want to bother with the cement board you could probably find a tile mastic that will bond to the paint. Make sure the paint is bonded to the wall, though.
What type of wall/paint in this shower without tile Thomas901 Tile Forum/Advice Board 3 05-21-2015 12:08 PM
Paint, and wall tiles tile student Tile Forum/Advice Board 3 11-23-2008 02:40 PM
tile over old wall/paint moschwartz Tile Forum/Advice Board 10 10-15-2007 06:03 PM
Swanstone wall - Install over finish paint? jcallen Tile Forum/Advice Board 1 08-27-2007 03:25 PM
How To Paint/Restore Tiled Wall? NCLloyd Cleaning, Restoration and Sealing 2 01-15-2007 07:56 PM
