Unread 07-19-2014, 07:09 PM   #1
wessendorf15
tile/stone setter
1500 sq/ft job advice
hi my name is brendan im sorta of new to the contractors thing been doing tile work for 5 years now and im just starting a business. for myself laying tile. i have done some rooms and other small things bathroom remodels act. i just got a call for a house for 1500 sq/ft and was wanting some advice on how to measure and square it out. and any other tips to make my life easier and get the job done a little quicker. thank you
Brendan
wessendorf15 is offline   Reply With Quote
Unread 07-19-2014, 07:18 PM   #2
Brendan,
Welcome to the forum.
I suggest buying and studying John's books, and reading the library here on the forum. Then get lost in the threads of the Pro's hang out for a few days.
Unread 07-19-2014, 07:20 PM   #3
wessendorf15
tile/stone setter
ive done it for awhile with a quality guy. but im young 21 years old and i know but i need to know any advice that could help me with future jobs
Brendan
Unread 07-19-2014, 07:34 PM   #4
Tiger Mountain Tile Inc
Brendan, welcome!
When you say "advice on how to measure and square it out"- what does this mean? Are you referring to the bidding process or the installation end of it?
James Upton
Unread 07-19-2014, 07:41 PM   #5
Jim Cordes
can't just know everything that quick...get the job, ask for advice, do the best you can,....study as you work. very important to research every job as you get them ...then before you know it you will start feeling comfortable.
yea it can be scary but being prepared helps alot.
you can even post pics here and ask questions. as far as bidding..that can be hard to do until you get rolling and find out what you need to charge..
give the customer the best job you can do and you will prosper. if you don't then not only will you have many problems but you won't get repeat business.
knowledge is power....power is money
Jim
Jim Cordes is offline   Reply With Quote
Unread 07-19-2014, 08:56 PM   #6
wessendorf15
tile/stone setter
that's what i have been doing and i seem to be doing quality work and getting referred out alot to my customers friends. this job is very important cause its for a high ranking military man who could be detrimental to my word of mouth. so i want it to be perfect
Brendan
Unread 07-19-2014, 09:50 PM   #7
Hi Brendan, welcome. Like the others said, read, read, and read some more. By reading, you will find some things you're doing wrong. You'll also learn how to do things the right way. I can say this because all of us here have been in your shoes. I've been around tile work all my life and been setting tile nearly 40 years and I'm still learning.
Unread 07-19-2014, 10:42 PM   #8
After the reading, ask a few thousand questions.
Unread 07-20-2014, 09:46 AM   #9
PetrH
"how to measure and square it out" Here's how I do it. I take the longest wall in the largest room, or the longest hallway that leads to a large room. I snap a line parallel to that, one tile +1/8" out from the wall. then I check every wall in the house off of that line to make sure I don't end up with any slivers 2" or smaller. Then I repeat with a perpendicular wall, keeping that line square to the first line. For a whole house this can take a couple of hours to do properly.
Also figure out some narrow points every 15 to 20 ft to put in expansion joints.
Petr
Unread 07-20-2014, 10:30 AM   #10
Jim Cordes
don't trust exterior doors or cabinets, use a long straight edge on the wall if it is wavy, don't measure off of joint compound in the corners, measure using the widest distances for more accuracy,learn how to do a 3-4-5 to check and how to use it to get a perpendicular line off of just one line.if using spacers understand how they will creep over distance,use different color chalk lines for layout and final lines, understand when its best to center the room and when it will be better to start full tile off of noticable places. make sure crooked walls are less noticable by having bigger pieces on them.. There are alot of little tricks to make the job look proper. It comes with time
you should know basically what size cuts you will have on all the walls before you start setting tile
Jim
Unread 07-20-2014, 10:32 AM   #11
HS345
Tile Contractor
HS345's Avatar
An accurate laser square can really speed up this process. "Accurate", being the key word. Don't buy the $49 Stanley at Home Repo, I made that mistake. Learn from my mistake.
The name's Greg
Unread 07-20-2014, 01:14 PM   #12
I'm with Greg, a laser is a great tool for this. I have one that shoots a 90* L beam and I can set it parallel with one wall and check others at the same time.
Unread 07-20-2014, 06:13 PM   #13
wessendorf15
tile/stone setter
wow thanks guys for the advice! i have been in it over 5 years with a guy and its a totally different story when you have to do it all on your own! im really liking this forum and is going picture my progress with you guys !
Brendan
Unread 07-20-2014, 07:02 PM   #14
Autoplay
Tile Setter
How did the guy you worked for/with....layout floors etc?
Rich
Unread 07-20-2014, 07:20 PM   #15
wessendorf15
tile/stone setter
when i watched he squared it out then would go from the walls and measure the walls. i just never understood how he did it. and dont want to ask cause im trying to fill the schedule in with him still while i slowly grow my clientele.
Brendan
Gonna pull the trigger onna Chev 1500 tomorrow - any thoughts? MudMaker The Mud Box 115 08-02-2013 08:56 AM
1500 sq/ft tile - installation karencitas Tile Forum/Advice Board 5 12-12-2012 05:54 PM
daunting 1500+ square feet of tile need help!! raventran Tile Forum/Advice Board 2 04-17-2011 06:40 AM
Laticrete 4237 with 1500 series Grout Lia Tile Forum/Advice Board 17 09-27-2006 09:07 AM
My new MBath - 1500 lbs. of tile drfarley Tile Forum/Advice Board 4 02-01-2004 08:46 AM
