posted by Craig,
How does one properly install Bull nose on a 90 degree inside corner and around the border of field tiles? I'm concerned that the corners won't look right since the edges of the bull nose won't line up properly.
Craig,
Couple different ways of using the bullnosing. People do it differently and its usually a matter of preference on what the person likes better. Are you doing a tub surround or full shower? One way if your bullnose tiles are the same size as your filed tiles. Keep all the joints lined up and on those outside corners try to get ahold of what they call corner bullnose pieces. The piece will have two finished sides and accommodate your outside corners. Inside corners just run the bullnose pieces together, or miter em.
Option number 2 - Stagger your bullnose pieces to your field tile, outside corners you miter, (2) 45 degree cuts to make your 90 degree turn. To make it clear this is the same kind of cut you would make around a door frame to put your casing up. If your bullnosing pieces are not the same as your field tiles, then this is your only option.
