Unread 10-18-2009, 10:44 AM   #1
melissadurante
Smoothing rough edge on glass tile
Hey everyone...I have some slightly rough edges on some glass tile that I cut..I was reading that you can smooth these out by using emery sticks...I found a sight online...but don't know what "grit" I need to use.....can anyone give me some advice?
These are glass mosaic tile
Melissa
melissadurante is offline   Reply With Quote
Unread 10-18-2009, 11:43 AM   #2
tilejoe
tilejoe's Avatar
You can use regular sandpaper too. I would start with a relatively high grit, like 220 or 320.
Are you trying to polish the edge, or just clean it up?
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 10-18-2009, 01:15 PM   #3
melissadurante
I'm just trying to clean it up.....I kind of tiled a small wall in my dressing room...and I didn't use the plastic edging....at first I figured grout or caulk would "hide" the rough edges....but I think it'd just be a lot better if I just smoothed them out..lol
Unread 10-18-2009, 04:39 PM   #4
Rob The Glass Man
You need to get some silicone carbide sand paper. I have a Mikata 5" disc sander I use with a stick on pad, works great! You can also use a belt sander. You could also use a diamond hand pad like the one shown in the link.
http://www.technologylk.com/_Z2B1201...-Hand-Pad.html
Rob
Rob The Glass Man is offline   Reply With Quote
Unread 10-18-2009, 04:41 PM   #5
johnfrwhipple
Try the belt sander
We have used the belt sander with good luck before.
johnfrwhipple is offline   Reply With Quote
Unread 10-19-2009, 05:14 PM   #6
melissadurante
Hey guys....just used some 100 grit sandpaper with some water and it smoothed out the edges perfectly....thanks!
Making cut edge rough.. piastrelista Tile Forum/Advice Board 4 06-29-2009 04:17 PM
Making cut rough-edge tile (like Cerdomus Pietra d'Assisi) look good miamicanes Tile Forum/Advice Board 12 06-04-2009 07:07 PM
Smoothing glass tile edge melissadurante Tile Forum/Advice Board 2 02-23-2009 04:24 PM
Smoothing porcelain tile edge SusanT Tile Forum/Advice Board 8 03-09-2008 04:40 PM
Glass Tile corner edge catch-n-on Tile Forum/Advice Board 6 04-10-2006 10:52 AM
