Hi all -
My husband and I are getting ready to tile our kitchen floor, plywood over wood joists, with 12"x24" porcelain tiles. The floor is solid and level for 90%. But the entry (coming from hardwood floor) and area where the refrigerator sits has quite a dip in it (we think the framing turns 90 degrees and is why it is only this small area). We can use SLC to level the refrigerator area, but my concern is at the transition. Right now, the subfloor drops enough at the entry that "level" is from the subfloor about 2' away to the top of the hardwood (about a 3/4" drop in the subfloor). To make things worse, this drop in the subfloor tapers from 3/4" to 0" across the opening (about a 4' opening). If we use SLC to make the tile area level, we will be VERY high at one edge of the wood (1/4" backer on mortar, 7/16" tile on mortar - almost an inch??) AND not level with the wood (because the wood is not level). Does anyone have recommendations for this situation? We could put a trim piece over the transition but for that much of a difference I'm not sure it will work. Plus, if the hardwood is not level, then I'm not sure how the trim will sit against the hardwood if we level the tile. Is there ever a situation that supports not leveling tile and matching adjacent floor finishes instead?
Sorry for the long post, I'm new at this.
Thanks for help in advance!!
